Old 08-09-2019, 07:20 PM   #1
SilverGT3RS
Help with LS swap radiator hose
Trying to see if anyone can help me with the radiator hoses for my 67 C10 with 6.0 motor LS swap.
I’m running an Entropy radiator, With the passenger side outlets and according to them I needed a lower hose off a Silverado and an upper off a Mitsubishi.
In short, that’s a FAIL. It’s not even close.
I don’t even know where to begin to try to figure it out.
Any help is appreciated.
SilverGT3RS is offline   Reply With Quote
Old 08-09-2019, 11:10 PM   #2
sprint_9
sprint_9's Avatar
Re: Help with LS swap radiator hose
I cant speak for certain on the top, but I know on the bottom you have to cut it to fit. Did you cut it to only use the part needed?
I would assume the same appies to the top one as well.
sprint_9 is offline   Reply With Quote
Old 08-10-2019, 12:05 AM   #3
mongocanfly
mongocanfly's Avatar
on my 81 I made wire templates from tig rod ...carried those to the parts store to help match up what I needed... had to shorten top hose...bottom hose is 2 pieces..
doubtful there will be a hose that fits perfect with no mods
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-10-2019, 07:14 AM   #4
72MARIO
72MARIO's Avatar
I used 1996 jeep grand cherokee 4.0 upper and lower hoses trim a little of the ends and perfect fit. I used a rnd rad bit outlets should be the same size
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-10-2019, 07:59 PM   #5
SilverGT3RS
The lower outlet on the Entropy is angled up. Is it the same on the RND?
Thanks!
Old 08-11-2019, 12:06 AM   #6
SierraMtns
SierraMtns's Avatar
Do you have the inlet/outlet size on the rad?
SierraMtns is offline   Reply With Quote
Old 08-11-2019, 09:06 AM   #7
SilverGT3RS
1-1/2 on the lower, 1-1/4 on top
After a ton of searching it looks like a Gates 21439 might work on top....but the angled lower outlet is really complicating things for the hose.
Old 08-12-2019, 11:18 AM   #8
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Here is what I used with my 6.0 and Entropy.
Upper Gates 21439
Lower Gates 20687
Had to cut the lower, but they both fit great. You can look at my build thread to see them
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 08-12-2019, 09:06 PM   #9
SilverGT3RS
Upper Gates 21439
Lower Gates 20687
Thanks so much....I ordered today. Another question-are you using the top port above the upper hose outlet for your steam vent?
Old 08-13-2019, 11:09 AM   #10
1971Stepside
Almost Satisfied
Yes, I used the stock hose clamp to clamp it to the upper radiator hose. It needs to relearn its shape a little, but it lays pretty well. This pic was a test fit before I clamped it all.
Old 08-13-2019, 11:30 AM   #11
SilverGT3RS
Excellent thanks so much for the info.
Where did you get the clamp? Is it off a late model Silverado?
Old 08-13-2019, 11:50 AM   #12
1971Stepside
Almost Satisfied
My motor came out of a Yukon Denali, so not sure if the Silverado has the same clamp or not.
Old 01-07-2024, 01:45 AM   #13
binford
I found this thread and I have the Cold-Case LS swap radiator.
GMT558ALS which has a 1.5" in and out.
To get the Gates hoses to fit I bought an adapter.
ICT Billet 1-1/4" to 1-1/2" Inch Hose Barb Splice Coupler
Not sure why Cold-Case puts an 1.5 inch upper, when the LS engine is 1.25, so now I'm adding a reducer aka adapter, to the hose.
I down loaded the Gates catalog and Gates Radiator Hose - 20801 might be an alterative, but I have not held that hose in my hands. But it is 1.5 to 1.25
I have the two gates hoses mention above.
binford is offline   Reply With Quote
