4l80e trans in K10 - Transfer Case Adaptor - Tone Ring ??’s
Swapping 2004 lq4 with 4l80e trans into my ‘72 K10 w/ 350/TH350 and NP205 transfer case. Advance Adapters makes a kit to mate the 4l80e to the NP205 transfer case. However, AA says the 4l80e will require a tone/reluctor ring install - which sounds like a pain in the a$$. Is there any way around the tone ring installation?
#2 | |
Moderator
![]() Join Date: Jun 2017
Re: 4l80e trans in K10 - Transfer Case Adaptor - Tone Ring ??’s
https://www.novak-adapt.com/catalog/...e-to/kit-4l81/ The tone ring kit is available from Novak Adapt...the link has all the details... I assume you will be using a standalone trans controller... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
I’m trying to avoid the tone ring install. Is it possible to use the transfer case from the donor ‘04 vehicle? And then eliminate the tone ring issue altogether?
Posted via Mobile Device |
All about them K’s
![]() Join Date: Jun 2014
Nope the drop is on the wrong side. Unless you can find a 91 crew cab 205 that came behind a factory 80e (hens teeth) in order for it to work correctly your going to need the tone ring. I’ve seen where some guys run a manual valve body and ditch the tone ring but that isn’t ideal to say the least. The factory computer shouldn’t be a problem if you get the tone ring setup.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 08-26-2019 at 11:43 PM. |
And I hope to use the stock ECM.
You are correct. Wrong side. Just trying to think this through b4 I spend any more than I have to.
Collector of Projects
![]() Join Date: Sep 2017
I will be doing the same swap LQ4/4L80E in my 72K2500. Try to find a 205 from a square body that had a th400 in front of it, they are hard to find but that the ticket. I got lucky and found one and it's a direct bolt up. The 4L80E is a th400 with overdrive and the bolt pattern on the tail and spline count are the same. Somebody please correct me if I'm wrong
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
#9 | |
The ORD link above has good details on the NP205 Last edited by mcmlxix; 08-27-2019 at 10:17 AM. |
All about them K’s
This is the unicorn I spoke of earlier in this thread.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Mar 2003
If you get a stand alone controller you don't need the tone ring in the t-case. You can program it to use the rear speed sensor in the trans. If no sensor in the transmission you'll have to install one. Worst case is no tone ring internally. If that is the case, then you'll have to have a trans shop put one in
#12 | |
All about them K’s
I thought I remembered that but I wasn’t sure. I knew something was different.
Thanks for all the input.
#15 | |
Tags |
4l80e, ls swap, np205, reluctor, transfercase |
