snorkel/intake
What you all using for snorkel? I want to keep battery on the passenger side and run the air intake/snorkel on the driver side if possible.
![]() ![]() Join Date: May 2015
Re: snorkel/intake
Some more info would be nice....and some pics...
What I did was use spectre couplings,90s,and filter...figured out the shape and size for the alum tube..got that off ebay
Not able to take pics yet. Engine isn’t in.
1971 c10. 5.3 truck motor with its factory accessories. E fan. Posted via Mobile Device |
![]() Join Date: Aug 2018
Re: snorkel/intake
You can buy the Spectre SPE-9900 kit and flip it around, we did it on my dad's by swapping the fittings from what Spectre shows in their pictures. You might even be able to modify the shield to attach to your core support.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
Re: snorkel/intake
since the engine isnt installed , i wouldnt buy anything unitl its in place ...then youll see what you need..
Re: snorkel/intake
^^What Greg said.
I usually build my intakes. Get a piece of aluminum or stainless. Make a few pie cuts and weld it up. You can tape it together or mark it up and have someone weld it if you aren't set up to weld. Here is one on a Nova I did. ![]() ![]() Here is my truck. I used a piece of scrap stainless and a $20 filter off ebay. ![]()
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Re: snorkel/intake
Superfastracing 4" Cold Air Intake System + Heat Shield for 1999-2006 GMC/Chevy V8 4.8L/5.3L/6.0L / Silverado 1500/2500/3500 (Black)
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Cheap easy and works. 71 with on the pass side. Cut it up or do whatever you want as it gives plenty of options for fitment.
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King! '83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress '92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress '79 Porsche 911 SC '48 Spartan Mansion 30' travel trailer '10 Porsche Cayenne S - Daily |
![]() Join Date: Dec 2012
Re: snorkel/intake
This is my plan! But I moved my battery under the bed!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
![]() Join Date: Mar 2013
Re: snorkel/intake
Here is how I did mine. I bought a 4" 180° mild steel mandrel bend from Summit. Cut it in half, used a couple of couplers, made a little bracket and presto. Turned out pretty nice.
Hump hose at TB 4 to 3.75" for both sides of MAF sensor Mandrel Bend Filter |
