09-01-2019, 01:40 PM | #1 |
neutral saftey switch
so i am using a van tilt column in my 71 c-10 and had to remove the neutral saftey switch fromt he column as the brake rod hits it and broke it soo. i got to thinking why cant i use the stitch on the side of the 4l60e as my neutral switch and back up light switch? so amone have a pin out for that switch on a 2004 silverado 4.8 4l60e?
09-01-2019, 03:23 PM | #2 |
Re: neutral saftey switch
Not sure of your exact connector on the side of your 4L60E, but in 2004 GM used this connector.
09-01-2019, 03:30 PM | #3 |
I will try to crawl under and snap a picture of the switch that is there so i can find the right plug for it and know which i need
09-01-2019, 09:42 PM | #4 |
I've posted the diagram on how to wire it up several times in the last couple of months.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
09-01-2019, 09:59 PM | #5 |
Thanks man ill find it
09-08-2019, 08:55 AM | #6 |
02-17-2020, 11:07 PM | #7 | |
I reached out to admins about getting it stickied ..... and never heard back. Be good for others to try and get it done as well.
FAKKY 57 PANEL BUILD |
09-08-2019, 04:57 PM | #8 |
02-17-2020, 10:23 PM | #9 |
Picture of pinot
02-17-2020, 10:27 PM | #10 |
Let me see if I have this right I can bring my backup lights
hot to pin c and out on pin f Can I bring starter signal in on e and out on g? Will switch on trans stand anought current for starter signal or am I going to need to wire a relay in? And use the relay to carry the current for starter signal?
02-17-2020, 11:09 PM | #11 | |
02-18-2020, 02:32 AM | #12 |
Thanks!!
05-27-2020, 01:49 PM | #13 |
Thanks guys got it all wired up with relay now have a nss safety switch and backup lights again!
