Old 09-04-2019, 09:19 PM   #1
72longstepper
Getting ready to put parts on long block----
Been over 50 years------------------------------
1. In what order should I put on the timing cover and oil pan.
2. Is it necessary to spot weld oil pump arm to keep it in place?
3. Do you use RTV on every gasket? Was Permatex in my day.
I will be putting an Edlebrock intake on. Would it be safer to install engine with a load leveler system rather than a carb plate (I have both). Front end is off.
ANY help is appreciated.
72longstepper is offline   Reply With Quote
Old 09-04-2019, 10:26 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Getting ready to put parts on long block----
1. It's easier to put the timing cover on first if it hasn't been cut to ease re-installation of timing chain and gears in its past life. If it's been cut it won't matter too much.
2. I've never spot welded a pick screen to an oil pump. Once I had one fall off, but I had it knurled and hammered it back on.
3. Do what the package says for the gaskets. Ye olde Permatex still works fine.
If the trans is in place in the truck, I'd go with the carb plate, personally. FWIW, I've never used a carb plate, just chains on bolts in the block or intake manifold. Either one is as safe as the other.
~Steven
Simi Valley, CA
Old 09-04-2019, 10:39 PM   #3
HO455
HO455's Avatar
What Steveedee says is good information. The only thing I would add is don't bother with the front and rear gaskets on the bottom of the intake manifold use RTV or a gasket maker product instead.
RIP Bob Parks.
Old 09-05-2019, 01:01 AM   #4
weim55
If the the oil pump and pickup are both new and of good quality the interference fit will be very tight making a spot weld unnecessary IF you use the proper tool to install the pickup into the pump. Bottom line if you can easily move the pickup in the pump fully installed do the spot weld.
Load leveler is great to ease install IF the engine hoist will raise the engine high enough (most don't) to clear everything using the leveler.
Yes, timing cover first, then oil pan.
I use light sealant on every gasket for an engine I plan to never take apart (ie: stock street motor). I HATE leaks down the road.
Tip: (this is necessary only if the long block is a rebuild or using a cheap china timing cover) before you permanent install the timing cover: install the timing cover dry on the block and slide on the balancer just enough before the seal surface to starts contacting balancer seal. Check the gap at 6 and 12 oclock to make sure they are the same. If you can see a difference with the naked eye the engine has excessive line bore machining and that seal will leak. Check 3 and 9 oclock positions too (china timing cover) This condition is very rare but a total drag if your engine has to come apart later to fix this.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 09-05-2019, 04:48 AM   #5
Grumpy old man
Grumpy old man's Avatar
I've seen a few different ways to secure an oil pick up tube to the pump and a few failures , JB weld , tack weld that cracked the tube both of those led to oil starvation and failure , when I installed a new Melling pump in my 350 I used a Pioneer oil pump pick up tube retainer from Summit and I'm sure it will do the job .
https://www.summitracing.com/parts/p...yABEgLTGvD_BwE
Also a good tip on the crank timing cover seal install worth a look .
https://www.youtube.com/watch?v=WOfOHMI6Wnc
These little install tips could save you big headaches down the road .
Old 09-05-2019, 04:57 AM   #6
Grumpy old man
Old 09-05-2019, 04:08 PM   #7
68Gold/white
I've never NOT welded a pickup tube...
Two years ago I freshened up a 350 for a friend. I measured the pan depth, then got online into Moroso's catalog. I bought a pickup that bolts to the pump body itself, using two of the pump housing bolts...THAT is the best way!!!
68Gold/white is offline   Reply With Quote
Old 09-05-2019, 05:56 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Probably 100 Million of them were pressed in that didn't fall out. And I got one.
~Steven
Simi Valley, CA
Old 10-02-2019, 04:24 PM   #9
72longstepper
TY all for replies and sorry for late response. Heart problems have put me way behind.
Old 10-02-2019, 04:55 PM   #10
AussieinNC
Moderator
AussieinNC's Avatar
Hi,
Best wishes on a speedy recovery from your heart issues....
and you are not way behind...at least you are looking at the daisies from above the ground!
I know I do everyday....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
