seat belt mount
ok, im at the point of mounting a 3 point seat belt in my '49 - 3 window cab.
Ive searched this forum & cant find any pictures to help locate the upper belt mount. any pictures or ideas would be appreciated. thanks |
![]() ![]() Join Date: Nov 2008
Re: seat belt mount
Here's how I did mine. No, it's not an AD truck it's a '55.2 Task Force but the same basic idea should work. If I had it to do over again I wouldn't locate the hole dead center on the pillar. it prevents the shoulder belt from hanging correctly. The belt tends to bunch up on one side of the metal it goes through....which gums up the inertia reel. Not a big deal but I'd prefer if it worked smoother.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Re: seat belt mount
I just reached in behind the double wall of the cab to place the pad. Make sure you don't drop it or you'll never get it out!
1951 Chevy Panel Truck |
Re: seat belt mount
miracle pie: I was looking at mounting the top point like you did but I think that would put the chest belt across my neck. I haven't test fit the belt yet.
Re: seat belt mount
what about the adjustable/ sliding mount from a newer Tahoe/ Suburban?
Re: seat belt mount
I dfid mine like miraclepie. I sat up in the truck like I was driving. Made vroom vroom noises and everything. And held the belt across my chest just where I wanted it and marked the spot. Bottom already mounted, and belt buckled across my lap first.
I did drop a nut plate behind driver side....
1950 Build |
Re: seat belt mount
Here's a write up on the install process. Juliano's is a popular aftermarket seatbelt company
https://www.julianos.com/Articles.asp?ID=277
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
Re: seat belt mount
hey guys - got a set of belts from Juliano's and have looked at the mounting instructions. haven't had time to test fit them yet but maybe this weekend. been busy trying to sort out a brake problem.
thanks for the info |
Re: seat belt mount
1950 Build |
