12-03-2003, 03:12 AM | #1 |
Seeker of the big and bad
Check this out!
My friend at www.rockcrawler.com just hooked me up. He makes a bracket that fits the 3/4 ton truck rear axel that let you bolt the rotors and the calipers off the front of a 67-71 3/4 ton on the back.4 wheel disk brakes in a hour!. don't forget to remove or change the porportioning valve.You need equal pressure now.
71 3/4 ton 4x4,665hp 454. 67 GMC 1 ton towtruck 68 chevy LB 4x4 64 chevy LB custom 57 Bel-air 2d station wagon |
12-03-2003, 03:24 AM | #2 |
That's awesome!! Now what about us 1/2 ton guys??? We don't get any love???
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
12-03-2003, 03:26 AM | #3 |
I'll hit him up and see what he comes up with,he's clever like that.
12-03-2003, 03:29 AM | #4 |
I've been trying to find a kit at a reasonable price, but you have to run larger than 15" rims. I like my ralley's!!! Let us know!!!
12-03-2003, 03:33 AM | #5 |
These brackets cost me $14 each and I had the 3/4 ton front end in the back 40.I'll see him tommorrow so I'll let you know
12-03-2003, 11:24 AM | #6 |
A-Adam A-Adam
I am interested in hearing how it goes!
70 3/4 ton GMC Camper Special |
12-03-2003, 04:08 PM | #7 |
I'd like some info too, maybe some pics of the swap, thanks, Don.
12-03-2003, 04:11 PM | #8 |
Blazerless:-(
I'd love info too!
12-03-2003, 04:55 PM | #9 |
Please keep us posted
Thanks! Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
12-03-2003, 05:08 PM | #10 |
That would be killer - if he will sell me a set for that price I will buy them! They are for the Eaton axle, correct? Then only have to source the rotors and calipers from someone on here, hmmm.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-03-2003, 05:28 PM | #11 |
Not my good side.
I'm interested, too! Got any pics of a finished, installed product? Will the bracket bolt up to a Dana 60?
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress. 00 Suburban LT 90 Camaro RS 79 Yamaha XS1100 Special (Ol' Reliable) |
12-03-2003, 05:36 PM | #12 |
I'm jumping in on this bandwagon for the 1/2 ton guys.
Please let us know!
Life is full of choices and a Chevy is the best choice. 1990 Chevy SWB |
12-04-2003, 12:43 AM | #13 |
wanted to keep this at top till we have some pics and details
12-04-2003, 12:47 AM | #14 |
its all about the +6 inches
A new prop valve is needed...but not equal pressure. The rear is lighter than the front...esp when braking. An adjustable one from jegs or summit would be the way to go.
Any provisions for a parking brake on his set up? (Some states need it for inspection) Last edited by Longhorn Man; 12-04-2003 at 01:44 AM. |
12-04-2003, 01:42 AM | #15 |
Ya,ya, me want info too please. Thanx bad4x4
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
12-04-2003, 02:48 AM | #16 | |
12-04-2003, 11:41 AM | #17 |
On the setups I have seen made to convert to disc brakes, you do usually loose your parking brake. I have seen people add one to their rear transfer case output.
12-04-2003, 05:54 PM | #18 | |
Not my good side.
12-04-2003, 06:51 PM | #19 |
CCRider
Bigger trucks and motorhomes have parking brakes that mount to the driveshaft on the tail of the transmission....easy retrofit
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
12-13-2003, 11:58 PM | #20 |
use a 76 - 78 caddilac eldorado caliper. they will mont up to the same holes and have a parkintg break lever. those are the ONLY years that will work. just gaoot fab the cable to pull right. no biggie.
69k5 |
