Old 09-24-2019, 05:49 PM   #1
67 gmc panel
Doors
Does any body know if 1967 c10 pickup doors fit on 1967 gmc panel?
67 gmc panel is offline   Reply With Quote
Old 09-24-2019, 06:47 PM   #2
CG
BlahBlahBlah
Re: Doors
The actual door is the same. The window frame is different. Panel is squared off while trucks are rounded off. Ive never done it myself but I hear its fairly simple to swap window frames. Something about only being spot welded on.
BTW 67-72 doors will fit. There is a little inner door item that's different on 72's because of the plastic door panels, and a little screw by the wing windows, but the doors still fit.
Old 09-24-2019, 06:49 PM   #3
HO455
HO455's Avatar
Re: Doors
Welcome aboard!
The answer to your question is no, not without modification. If you took the square cornered window frame on your panel door and replaced the round cornered window frame on the pickup door it would work.
Suburban doors will work without modification.
Whoops I see CG is a faster typist than I am.
Never the less welcome and we would like to see pictures of your panel.
RIP Bob Parks.
