Could you get a 1968 C10 with power brakes? What does booster and bracket look like?
I am not sure if 1968 Chevy C10s had power brakes but if they did does anybody have some pics of what the booster and bracket looked like?
Was the booster 11inch or 9 inch? Are aftermarket 9 inch boosters better than 11 inch boosters? |
Re: Could you get a 1968 C10 with power brakes? What does booster and bracket look li
O’Reillys auto parts shows a power brake booster for it so I assume it was available. My understanding is that a larger booster equals more boosting. I think smaller is a compromise for engine compartments with limited space.
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
i have yet to find pics of a original 1968 Chevy C10 with power brakes. I was very sure that it wouldnt be very difficult to find a example but I have not seen one yet.
![]() Join Date: May 2012
I had this truck and sold it. It had power brakes. It was a 68 CST half ton. As far as I know the power brakes were factory. That's all the info I have. Hope it helps.
I have a 67 Longbed donor truck thats pretty loaded for way back then ,Power Brakes ,Power Steering ,front stabilizer bar , tinted windows , A/C ,Posi Rear end ,Overdrive trans ,BuddyBuckets ,wheel covers ,side trim , push button radio ,big back window . Its complete less motor . Im sure 68 could be ordered the same . Have pics I can text to anyone that wants to see as I cant post pics .
I didn’t start the thread but have been thinking about the same for my 68 c10 Sub— is it as straight forward as putting the booster on and hooking it up or is there more I’m missing to upgrade? (I have a later c10 parts truck for disc swap someday but in the meantime)
My '67 had PB from the factory (they were on the SPID), but I'm afraid I don't have pics.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
![]() Join Date: Oct 2012
Check this thread on 'survivor engines' and look at post #18.
It's a 68 anniversary truck with P Brakes. http://67-72chevytrucks.com/vboard/s...rvivor+engines
Larry 84 Chevy SWB, "Roy", dark blue orig paint, 6 cyl auto, PS, 88,000 miles. 72 Highlander LWB "Olive" med olive over lt yellow, air, 77,000 miles (sold) "It's a sorry man who can't find his wife a good job" |
#9 | |
Nothing real rare about 67 or 68's with power brakes, you just don't see as many of those, as the 69-72's with power brakes.... |
The Older Generation
Here is a picture of my '68 C20, CST/Custom Camper and the SPID. I can get some closer pictures if you need them. LockDoc
Here is what I had on my 68 50th
![]() Join Date: Jul 2016
Post 4 is c20 later model booster and disc brake master cylinder and prop valve. Post 11 is correct booster master cyl and distribution block
Junior Member
![]() Join Date: Nov 2018
Hey Hauler - I recently swapped my 69 stock 11" booster and bracket for a 9" dual booster and bracket. When I installed a 4bbl intake and 390 Holley carb, there wasn't enough clearance between the carb and big booster. The stock booster and bracket are free (you pay shipping) if you decide to go that way.
Ken |
#15 |
![]() Join Date: Feb 2016
There is a quite difference between post 10 and post 11. The boosters as are different as are the master cylinders. Is that because one is a C10 and the other a C20?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#16 |
3/4 ton had dual diaphragm boosters I believe. On disc brakes they had bigger caliper pistons but the replacements seem to be the same as 1/2 ton
#17 |
I am a Referee of life.
From what I understand, there were two different set-ups. IIRC Bendix and Moraine. The boosters were different as were the MCs. I'm not sure about the brackets or application. I slightly rebent the brake lines on mine and they worked, it's a stretch tho. Something else to watch for is the MC piston depth. Some are shallow and others are over an inch deep. The deep one does not actuate with the smaller 9 in booster until you make a spacer. There's a post on it somewhere that came up in a search. I used a set-up from McGuagheys that was booster, MC and brackets. It's worked well for 12-14 years. I saw the same set from Inline tube at Charlotte Auto Fair and someone else also had it. Most of the BB vendors can hook you up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
