10-04-2019, 10:26 PM | #1 |
WTB Power Brake Booster Push-rod hardware
Looking for the hardware needed to attached the push rod to the brake booster bracket, with or without the pushrod itself.
Here are pics of what I have now. I need the parts to connect the pushrod to the booster bracket.
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
10-05-2019, 12:05 AM | #2 |
Re: WTB Power Brake Booster Push-rod hardware
I’ve got what you need, I’ll be taking it from a complete setup, so hows $12.50 shipped? Have everything else also if one of your pieces isn’t in good condition.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 10-05-2019 at 12:17 AM. |
10-05-2019, 04:54 PM | #3 | |
Thanks!
10-05-2019, 06:17 PM | #4 |
That’s just the hardware, just measured and it’s 9.25” center to center. Last time someone asked about the rod I told them $29 shipped.
I’m in a good mood so if you need both $27. Also I assume since you have a rod already then you have the correct pedal to rod bolt, but if not then $30 for the rod and attaching hardware on both ends. Needless to say whatever option you choose
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
10-05-2019, 10:03 PM | #5 | |
10-05-2019, 06:24 PM | #6 |
Those rod bolts like to disappear and turn up once you’ve replaced it!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
10-05-2019, 06:52 PM | #7 |
No kidding, exactly why I tape or zip tie stuff together now.
10-05-2019, 10:17 PM | #8 |
My pushrod measures 9.25 inches and it looks like I have the correct pedal to rod bolt. I will take the hardware, please. I plan to try and get it setup in the next couple of weeks, so if I need anything else, I will let you know.
Assuming my booster ends up not being good, is yours for sale? You take Paypal for the hardware? Thanks. I appreciate the help.
10-05-2019, 11:25 PM | #9 | |
10-06-2019, 11:53 AM | #10 | |
I thought I had included the photo of the pedal to rod bolt in the post. Here it is in case I am mistaken.
10-06-2019, 12:25 PM | #11 |
Hey Madkidd007, do you know what type of bolts I would use to attach the bracket to the firewall? As you can see in the pic above, two of mine are broken.
Thanks!
10-06-2019, 02:25 PM | #12 |
I have never seen one back off but just Incase since it has a hole, throw a cotter in there or even a nail just as a backup before you drive it. It’s been a while on the bracket since I’ve looked, I thought they were pressed in studs in the pedal support. If you look at your picture you can barely see what appears to be knurles on the bolt on the inside of the firewall.
10-06-2019, 07:52 PM | #13 |
Confirmed they are studs and are tack welded in. Kind of a pain under the dash. Probably would be easiest to pull your brake pedal support if your truck is complete and don’t want sparks flying inside
10-06-2019, 08:02 PM | #14 |
The second one I nicked with the grinder and the threads need to be cleaned up. If you want them, send me $5 and I’ll send them too. Worked up more of a sweat than at work all day
10-07-2019, 11:07 PM | #15 | |
