Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-07-2019, 08:37 PM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
What Did We Call Premium Gas?
Was it Ethel?
It seems it used to be called a couple other things back in the day.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-07-2019, 08:39 PM   #2
Rickysnickers
Re: What Did We Call Premium Gas?
Ethyl, super, or high test
Old 10-07-2019, 09:58 PM   #3
rsavage
rsavage's Avatar
High test back in the day in my neck of the woods.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 10-08-2019, 07:03 AM   #4
Blue666(2)
Originally Posted by LostMy65 View Post
Was it Ethel?
I found a few sources for info. Gasoline, in it's most basic form, is a natural byproduct of crude oil production. Some crude oils naturally seperate into heavy & light distillates while in storage. Refining further breaks crude into many products.
These light distillates were little used until the early 1890's when spark ignition engines began to appear. Natural gasoline was often wasted (dumped) due to safety hazards.
Gasoline research began as we tried to develop reliable & more powerful engines. The technologies grew together.
AT many gas stations, a buyer could selct a wide variety of octane levels. https://www.tommcmahon.net/2010/08/s...-gas-pump.html
I found this also but can't verify the source. https://www.stevesnovasite.com/forum.../t-164646.html
Blue666(2) is offline   Reply With Quote
Old 10-08-2019, 07:48 AM   #5
nsb29
nsb29's Avatar
Ethel
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 10-08-2019, 10:17 AM   #6
Clyde65
Clyde65's Avatar
When I was a kid, there was Premium Leaded and regular leaded fuel
Premium had higher octane to suppress knock
Then unleaded came and leaded was removed.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-08-2019, 10:57 AM   #7
NorCalC20LWB
Ethyl way back when. Had a job in my teens back in the mid '70's pumping gas at night in the Sacramento area (this was before self serve). One of my first nights an older gentleman said "fill it up with ethyl". Me, after standing there looking stupid: "Uhhh, what's ethyl?". Him: "The good stuff". Must be a term from the old days.
NorCalC20LWB is offline   Reply With Quote
Old 10-08-2019, 11:02 AM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
How many of you people worked at a gas station and pumped ethyl?
[raises hand]
We used to call it ethyl, but when I worked at a Chevron station they called it Chevron "Supreme".
~Steven
Simi Valley, CA
Old 10-09-2019, 10:15 PM   #9
LostMy65
LostMy65's Avatar
[raises hand]
That's right, I forgot... Supreme was another I remember.
Old 10-08-2019, 11:02 AM   #10
A1971Blazer
A1971Blazer's Avatar
Burt Reynolds in the movie WW and the Dixie Dance Kings
https://www.youtube.com/watch?v=hVcEqVcsE1s at 43:20
Gas station attendant: "You want regular or Ethyl?"
Burt: "We'll take Ethyl if she's working...if she ain't how 'bout her sister"
Sunoco 260 or Amoco Premium (both 104 octane) was our hot rod "go-to" fuel
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 10-08-2019, 11:15 AM   #11
The Rocknrod
Moderator
The Rocknrod's Avatar
Ethyl.
Old 10-08-2019, 11:30 AM   #12
Killer Bee
Killer Bee's Avatar
recently had to retire these old tanks that were ready to roll away and replace with newer ones on a slab..
the old gasoline tanks still had the old larger nozzles for leaded fuel, the new one got the smaller nozzle for modern unleaded..
ethyl was the brand name of the lead additive package that could be added to the tank at bulk fill up until around the mid 90's where it was banned completely..
we had ethyl in the smaller gasoline tank up until they quit selling it..
lead increases octane levels and lubricity specifically needed in older valvetrains and higher compression engines to reduce knock..
avgas 100 low lead is still available although can be difficult to obtain depending where you go or who you know..
and although labeled 'low' lead I believe is still higher lead content than premium leaded used to be..
race fuel I believe is still available in drums, not sure if available in bulk or not..
new ul listed 500 gallon tanks, sufficient fuel storage, oil company will deliver anything over 300 gallons without surcharge..
these 500s were installed in the 70's
and these 1000s added in the 80's
Old 10-08-2019, 12:03 PM   #13
A1971Blazer
Tetraethyllead (commonly styled tetraethyl lead), abbreviated TEL, is an organolead compound with the formula (CH 3 CH 2) 4 Pb..
TEL is a petro-fuel additive, first being mixed with gasoline (petrol) beginning in the 1920s as a patented octane rating booster that allowed engine compression to be raised substantially.
1967 C10 Step side
1968 C10 Step side
Old 10-08-2019, 12:31 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
In the Sixties on the west coast, Chevron had 3 grades of gasoline, and they each had their own pump color. IIRC, regular was in blue pumps, mid-grade in red pumps, and the good stuff, Chevron Custom Supreme, in white pumps.
As I recall, it had a hint of greenish color and was referred to as 'lime kool-aid'. It was the only gas my 375HP '65 Corvette was happy with.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-08-2019, 12:34 PM   #15
The Rocknrod
Moderator
I remember my dad being asked this question every time we stopped for gas:
Old 10-08-2019, 02:34 PM   #16
100%Chevy
Most of the gas stations i worked at in the late 60's/early 70's only sold 2 chioces---regular or premium.
The bigger brand s had several different octane ratings you could choose.Some even had a knob on the pump to select octane desired,which I think was a crock of bull.
Anybody remember "White gas"?
Mike.
100%Chevy is offline   Reply With Quote
Old 10-08-2019, 02:40 PM   #17
A1971Blazer
Mike.
Amoco..had the unleaded premium "white gas" you could use it in a Coleman lantern or camping stove....it was good fuel for hot rods too..
1967 C10 Step side
1968 C10 Step side
Old 10-08-2019, 07:06 PM   #18
LostMy65
LostMy65's Avatar
White gas didn't smell bad if I remember correctly.
Maybe it's because I don't like the smell of kerosene.
Old 10-08-2019, 03:00 PM   #19
Steeveedee
Who Changed This?
Steeveedee's Avatar
Mike.
It may have brought higher octane fuel to the dispenser, but I know that the hose alone holds a gallon, so unless the person before you got the same thing as you did, you may not have gotten what you paid for. Maybe that isn't true, but can anyone tell me how the switching was done? Guaranteed you were going to get one gallon different from what you paid for. Maybe better, maybe worse.
~Steven
Simi Valley, CA
Old 10-08-2019, 06:29 PM   #20
100%Chevy
Us poor folks would always drain the hose before hanging up the nozzle!
Mike.
Old 10-09-2019, 07:01 PM   #21
yuccales
yuccales's Avatar
Mike.
That's how we got gas for the mini-bike and lawn mower.
yuccales is offline   Reply With Quote
Old 10-08-2019, 05:33 PM   #22
67ChevyRedneck
67ChevyRedneck's Avatar
When did gas stations start advertising/assigning an octane level to fuel? I seem to recall that being a part of the pricing signs since I was little (1980's).
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-08-2019, 07:26 PM   #23
Hi-test or premium is what it was called around here in my time as the general terms. But since all stations were of the oil companies, we used the trade names like Esso Extra, Sunoco 260, Super Shell, (Texaco) Sky Chief, Amoco Premium.
I pumped gas at a Sunoco station in HS. Also mounted tires and took wrecker out to do hot shots or get people unstuck
Old 10-08-2019, 08:07 PM   #24
1976gmc20
The "wrecker" at the Conoco station where I worked was an old four banger Scout with a set of jumper cables and a tow strap
We used to do lots of "no start" calls in the winter. Usually it was to a motel for skiers from Texas who were still running straight 30 or 40 weight oil, which of course turns almost solid at forty below. If the jump didn't work, we would drag them into the heated shop for a few hours to warm up, often followed by an oil change and maybe a tune-up (points/condenser/plugs) and a new battery.
BTW, since people came from all over the country to that station, they called the most expensive gas by a variety of names so I never got stuck on one. I won't make any jokes about "pumping Ethel" - honestly, I won't
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
Last edited by 1976gmc20; 10-09-2019 at 11:39 AM. Reason: something about the topic
1976gmc20 is offline   Reply With Quote
Old 10-09-2019, 08:21 AM   #25
67C10Step
67C10Step's Avatar
I grew up in the sticks in north Arkansas and it was High Test or Super in my neck of the woods.
Would ride my 1969 Honda Z50 to the local country store, fill it up with gas, grab a soda and a bag of chips. All for about $1.
Didn’t know I was living the carefree life but I was.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
