10-08-2019, 06:54 PM | #1 |
6 rib p/s pump pulley
I am looking for a single 6 rib serpentine belt pulley with a 5/8" shaft with a keyway slot. I bought ones years ago and am now finally installing my motor and I managed to damage the pulley beyond repair. I do not want to have to purchase a whole a kit again nor so I want to spend the money on a March pulley. I am not having any luck. Any leads any where?
Thanks |
10-09-2019, 03:50 PM | #2 |
Re: 6 rib p/s pump pulley
I guess I am the only person out there that is using this type of pulley system, I will find my own solution without the help of this board.
10-09-2019, 08:19 PM | #3 |
well, I suppose, if someone had a answer to your problem they would have posted up. My only answer was to buy a March pulley or check out a junk yard. But, you disted the March idea, so that is why I didn't post up
10-10-2019, 12:07 PM | #4 |
You'll probably get a better response if you post in the 67-72 forum, not the build forum and have a little patience. Also, you can try using the search function. Not everyone gets on here every day even every few days.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
