Old 10-16-2019, 08:48 AM   #1
dagnabbitt
dagnabbitt's Avatar
C20 Tire Selection
So I recently pulled a 1968 C20 out of a field - build thread coming soon - and I need to make a decision on tires. It had some non-original split rims on it (I assume they were non original since they were 17" and not the 16.5s that were on the SPID), and tube tires that might actually pre-date the truck itself.
Fortunately I knew from poring over this site that I could put F*rd rims on it, and one day I realized that I had a friend with a bunch of E250 vans. So I got a set of from him and they of course fit great! Again without this site as a resource it would never ever occur to me that they would fit.
They are a 16x7 rim, any thoughts on tire size? I like the tall skinny look but a 7 inch rim is actually pretty wide compared to original, and I want something that suits the rims as much as it suits the truck: I don't like it when the tires are noticeably crammed or stretched onto a wheel. Would 235 85 16s look good on this rim, or should I go with something wider, like a 265 70 16?
If someone could flip my pics I would appreciate it.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-16-2019, 08:57 AM   #2
burb71
Active Member
Re: C20 Tire Selection
GREAT QUESTION
I'm interested to find out a good recommendation for this myself!
burb71 is offline   Reply With Quote
Old 10-16-2019, 09:16 AM   #3
dave6672
dave6672's Avatar
Here's my C20 with 235/85/16's on it.
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
dave6672 is offline   Reply With Quote
Old 10-16-2019, 01:15 PM   #4
dagnabbitt
dagnabbitt's Avatar
That's the look I like too, nice truck.
What kind of rims are you using, ie are they Chev rims, and how wide do you think they are?
Hope I can find some nice deep dish hubcaps like your too.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-16-2019, 01:55 PM   #5
burb71
Active Member
I'm wondering if going to the more widely available 16-inch size wheel and tire and ditching the 16.5 from the factory.
What size tire will equate to around the same ride height to give a more accurate speedometer reading?
Old 10-16-2019, 03:47 PM   #6
chevmn
Here is a set I have mounted using those same 16x7 Ford Accuride wheels, along with a set of stainless dog dish I restored (sort of hobby now, restoring those) which will eventually make their way to my C20. Tires are 265/70/16.
chevmn is offline   Reply With Quote
Old 10-17-2019, 06:39 AM   #7
dave6672
dave6672's Avatar
I got the rims at a local junkyard and are a mix, but are 16 x 6.5 if I remember correctly.
Dave R.
1972 K20
1972 C20 Highlander
1967 C10
Old 10-17-2019, 08:53 AM   #8
rpmerf
rpmerf's Avatar
I had some 265/75R16 tires on my truck for a bit. Mismatched unevenly worn tires on mismatched rims. I thought they looked really good. The width matched the height better than the 235's I thought. Like others have said, almost the same diameter, but an inch wider. I wish I would had realized it when I bought my current set of tires, I would had gone with the 265s.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-17-2019, 02:02 PM   #9
Furno68C20
FYI --If your going to do a front disc conversion the new spindles stick the tires our about 3/4" on both sides. I had tire rub on the inner fender when taking a sharp turn, which then i had to get smaller tires.
67 C10 Fleetside SOLD
67 C10 SWB Fleetside
67 C20 Fleetside
68 C10 Fleetside
68 C20 Fleetside SOLD
72 k20
Pay Pal: Grant.Furneaux@gmail.com
Furno68C20 is offline   Reply With Quote
Old 10-17-2019, 10:57 PM   #10
dagnabbitt
dagnabbitt's Avatar
I think I'm sticking with the drums but thanks I will keep that in mind.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-20-2019, 09:21 AM   #11
May70
May70's Avatar
What size tired rubbed Furno? Also 3/4 outside the fender well?? What disc conversion/spindles did you go with? THX
May70 is offline   Reply With Quote
Old 10-22-2019, 02:17 PM   #12
Furno68C20
May70. I used the conversion kit from Brothers. I dont remember the tire size but they were BF goodwrench all terrains. Maybe 265/70R16? pretty big tires.
Check out this post - http://67-72chevytrucks.com/vboard/s...d.php?t=528238
hope this helps
67 C20 Fleetside
68 C10 Fleetside
72 k20
Old 10-18-2019, 01:03 AM   #13
burb71
Active Member
dagnabbitt
I hope you don't think I hijacked your thread, or took it in a different direction from your original post.
Old 10-18-2019, 10:29 AM   #14
dagnabbitt
dagnabbitt's Avatar
Originally Posted by burb71 View Post
dagnabbitt
No not at all, looks like it is a topic that is on more than a few people's minds.
Doing some research I am leaning towards 265 75 16s now: a size that I hadn't even considered when I started this thread. Using a tire chart and going by some the photos and member testamonials provided I think they will look good... and for some reason or another they tend to be the cheapest tire of the three or four options I was considering.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-19-2019, 02:04 AM   #15
burb71
Active Member
Thanks, good to know
Old 10-19-2019, 06:31 AM   #16
chevmn
Here is a link to a magazine article where I got the idea on what I wanted to run (my wheels came of a early 90s Ford F250 from a local salvage yard for $20 each). There are simply very few good options for the 3/4 ton trucks when it comes to wheels. 16.5 tires are scarce now, expensive, and usually rated for heavy tow duty. I do not like any of the aftermarket wheels, and especially the ones from recent years (large diameter black aluminum wheels). This allows me to run a more common tire size, and the tires I currently have came off (believe it or not) a Toyota Tacoma which my wife drives, which are load range B tires, and should ride decent vs. the load range C, D, or E, many run...considering I do not plan on heavy towing or hauling. Only issue I have is keeping a set of restored hub caps as I keep selling the set I do for my own project, but I currently have a very nice, near NOS quality set set aside now for it.
Hope the owner of this truck does not mind, as I believe he is is a board member here...... One of my favorite builds....
https://www.hotrod.com/articles/1969...et-c20-driven/
Old 10-19-2019, 10:13 AM   #17
NoStopN
NoStopN's Avatar
Just some stock GM wheels from a 2008 GMC. Tires are LT265/70/17.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 10-19-2019, 10:23 AM   #18
72c20customcamper
72c20customcamper's Avatar
Firestone transforce 265/75r16 on ford rims I bought from roadreadywheels.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-19-2019, 09:18 PM   #19
2 Stovebolts
Trying to find the most correct looking wheel that was on my 67 K20, without split ring....Would like to keep with the tall skinny look...What are my options?
2 Stovebolts is offline   Reply With Quote
Old 10-19-2019, 10:19 PM   #20
Cali72K20
Cali72K20's Avatar
These might be what you are looking for in a 1967 vintage look that are tall and skinny
https://www.outdoortire.com/product/...eless-7-50-16/
https://www.walmart.com/ip/Deestone-...SABEgI-OPD_BwE
https://www.walmart.com/ip/Hankook-F...yABEgLktvD_BwE
Cali72K20 is offline   Reply With Quote
Old 10-20-2019, 12:02 PM   #21
dagnabbitt
dagnabbitt's Avatar
Originally Posted by Cali72K20 View Post
Those are some pretty cool tires, wonder if I can get them in Canada. It's illegal to drive on the highway with tubes where I live, so those outdoortire.com ones look to be the best option out of what you suggest. EDIT: Unfortunately outdoortire.com doesn't ship to Canada.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-20-2019, 12:44 PM   #22
Killer Bee
Killer Bee's Avatar
if yer looking for tubeless bias ply farm skinnies, STA makes a few..
lug rears and highway tread fronts in companion sizes..
Coker, Summit, etc. sell them so should be able to find someone shipping up north..
here's a post of mine from a while back but they have been discussed at length around the board..
good luck!
Originally Posted by Killer Bee View Post
STA, Specialty Tires of America [American Made] has the best selection and prices on farm skinnys I've found..
this is the brand Coker sells [in this tire type] for double the price, yes I was quoted
here's the last price quote I had from local tire vendor for the sizes I'm looking at;
LA4B5-$148
LA4C5-$156
LB4B5-$158
LB4C5-$161
transport fronts http://www.stausaonline.com/tires/sta-super-transport/
8.75-16.5LT A D/8 LA4B5 HWY 16/32 29.80 6.75X16.5 9.00 2070 60 2350 60 37
9.50-16.5LT A D/8 LA4C5 HWY 17/32 30.60 6.75X16.5 9.30 2445 60 2780 60 41
traxxion rears http://www.stausaonline.com/tires/sta-super-traxion/
8.75-16.5LT A D/8 LB4B5 M&S 18/32 29.90 6.75X16.5 8.80 60 2070 60 2350 37
9.50-16.5LT A D/8 LB4C5 M&S 18/32 31.10 6.75X16.5 9.50 60 2445 60 2780 41
sticking with the 16.5s I currently have due to better tire selection in this type of tire.. factory 15" 8 lug snap-rings too rusty..
Old 10-19-2019, 10:28 PM   #23
Cali72K20
Cali72K20's Avatar
https://www.summitracing.com/parts/C...CABEgJ4ePD_BwE
This one looks good but probably not highway friendly
Old 10-20-2019, 09:08 AM   #24
2 Stovebolts
Thanks for the comebacks on tires...but its the wheels that I'm asking.....
Old 10-23-2019, 08:03 AM   #25
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
275/70R-16 General something or another. I've recently went with Cooper 265/70R-16's...The 275's were like a 1/2" taller and a bit wider...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
