10-17-2019, 05:44 PM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Which late model truck axle will fit a '69.
For my '69 GMC 3/4 ton leafs with 8 lugs.
Thanks |
10-21-2019, 02:43 PM | #2 |
Re: Which late model truck axle will fit a '69.
I used a 2002-2010 2500 HD 14 bolt full float rear axle under my 1970 gmc 3/4 ton.. they are 14 bolt 8lug 10.5 ring rear, disc brakes are pretty cheap.. you will have to move the spring pads and at least one shock mount..
10-21-2019, 07:31 PM | #3 |
On my 69 I used a 14 bolt semi-floating rear with a 9.5 ring gear from a 80's square body 3/4 or 1-ton, I had to move the spring perches and the shock mounts, but that is fairly easy. U-joints are the same, overall a very easy swap, parts are readily available and many gear sets to choose from, I'm running 3.56 in mine.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
10-21-2019, 07:37 PM | #4 |
You wrote it's for your GMC 3/4 ton, most of them came with Dana 60's and those are excellent rear ends, just fyi.
10-21-2019, 07:44 PM | #5 |
One challenge with swapping in a later axle is do you want all your lug nuts to match? In '71 they went to 9/16" lug studs and in '88 they went to 14mm.
If you are planning a disc swap, those are 9/16" and get you a donor up to '87. I too am a fan of the semi-float 14 as an excellent value that is as strong as the Dana 60 in terms of ring and pinion.
