Old 10-31-2019, 09:36 PM   #1
ricktfd
ricktfd's Avatar
Brake issues on power brake update.
I have a 64 SWB C10 with brake issues. It has a 5 lug conversion, with disc front/ drum rear, but was non power. I recently installed a new dual booster/ master cylinder unit from CPP. I have good vacuum and the check valve is working properly. When I brake for regular stop and go traffic I have decent stopping. But at highway speeds or on hard braking, I have to stand on the pedal and hope I can get it to stop. It is as if I didn't have power brakes at all.
I am at loss on where to go now. Any ideas would be appreciated.
ricktfd is offline   Reply With Quote
Old 10-31-2019, 09:53 PM   #2
slepysal
slepysal's Avatar
Re: Brake issues on power brake update.
How is your vacuum to your booster,where are you pulling your vacuum from? Is the check valve good? Did you re drill your brake pedal?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-31-2019, 11:36 PM   #3
Captainfab
60-66 Nut
What is the diameter of the booster? And is it a dual diaphragm or single. The smaller the diameter of the booster, the less braking assist you will have. How much vacuum does your engine produce?
Old 11-01-2019, 08:05 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Do you know what the diameter of the brake cylinder is? Inside the master cylinder.
What size are your brake lines?
Old 11-01-2019, 08:38 AM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Try adjusting the pedal rod under the dash, I struggled and struggled with mine until I adjusted it to engage sooner.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-01-2019, 09:52 AM   #6
AcampoDave
AcampoDave's Avatar
Wait a minute, I have manual disc and I have never had to stand on the pedal and hope I can get it to stop at highway speeds or under hard braking. Is it possible that you already had some issues prior to adding the booster?
AcampoDave is offline   Reply With Quote
Old 11-01-2019, 10:46 AM   #7
The Rocknrod
Moderator
Also have you done the pedal ratio correct when you went to power disc?
Old 11-01-2019, 11:16 AM   #8
LostMy65
LostMy65's Avatar
I never did it on my 66. I left it in the same hole.
