Old 11-02-2019, 08:10 PM   #1
62 Barnfind
62 Barnfind's Avatar
57 Truck build
I purchased this truck last year spur of the moment because I was ready to start another project. I’m planning a full resto mod with a 4.8 and trans that I got for a steal. I have already removed the suspension and replaced it with a CPP mustang II and TCI rear springs. They didn’t send me the drop spindles so I took two inches out of the cross member and cut the springs.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 11-02-2019, 08:16 PM   #2
62 Barnfind
Re: 57 Truck build
Speedway universal LS engine mounts installed, mock up of the engine/trans, installed the firewall brakes and smoothed the firewall. Put the nose back on to check hood clearance.
John Z
62 Barnfind
Old 11-02-2019, 08:22 PM   #3
62 Barnfind
Re: 57 Truck build
Cut out the dash to make room for the smooth dash. I moved the temp control to where the ash tray was so I can use the vintage air controller.
John Z
62 Barnfind
Old 11-03-2019, 07:02 AM   #4
dug224
dug224's Avatar
Re: 57 Truck build
Moving quickly!! Signed up for the build.
dug224 is offline   Reply With Quote
Old 11-03-2019, 09:23 AM   #5
62 Barnfind
Re: 57 Truck build
Changed out the smaller rear end to an69 Camaro 10 bolt with 373 gears. This should go well with the 4.8 and it’s much bigger. I also pulled out the wheels and put some used tires on it for mock up of the bed sides for the wheel tubs.
John Z
62 Barnfind
Old 11-09-2019, 10:01 AM   #6
62 Barnfind
Re: 57 Truck build
Worked on the bed rails a little.
John Z
62 Barnfind
Old 11-09-2019, 10:07 AM   #7
62 Barnfind
Re: 57 Truck build
New parts came it! Hopefully I can get to mock them up this weekend! I also cratered my fender mount holes to give it a little more custom look.
John Z
62 Barnfind
Old 11-09-2019, 12:59 PM   #8
LT7A
Re: 57 Truck build
The aggressive lines and proportions of these trucks are so cool. I have mostly had Squarebodies and they have their own type of integrated coolness but none of the flair of this era. You seem very decisive in your progress and custom touches. I'm very interested to watch. Thanks for showing us the details.
Old 11-09-2019, 07:21 PM   #9
62 Barnfind
Re: 57 Truck build
Thanks! This is my second build of this body style. I have been looking at different ways to build it. I want something that looks cool with little custom touches. The body design already looks great it was just a few areas that needed some adjustment. My 62 build is more stock so I wanted to go in a little different direction. Thanks again!
John Z
62 Barnfind
Old 11-17-2019, 11:35 AM   #10
62 Barnfind
Re: 57 Truck build
Decided to work on the doors, rockers and cab corners. The doors was pushed in about a 1/4 in in some places. So I had to cut and push and pull to get the door edges right. I also started adding 3/16 rod to tighten the gaps. I’m learning that aftermarket doors are not straight. I still have some finish welds and grinds to do to make it look right.
John Z
62 Barnfind
Old 11-17-2019, 12:29 PM   #11
Black_Sheep
Black_Sheep's Avatar
Re: 57 Truck build
One to watch, following...
Black_Sheep is offline   Reply With Quote
Old 11-17-2019, 02:18 PM   #12
62 Barnfind
Re: 57 Truck build
Thanks! Hopefully it will come out as good as yours!
John Z
62 Barnfind
Old 11-22-2019, 11:47 PM   #13
71'tahoe
71'tahoe's Avatar
Re: 57 Truck build
Looking good!
71'tahoe is offline   Reply With Quote
Old 12-24-2019, 05:07 PM   #14
62 Barnfind
Re: 57 Truck build
Finally got to work on the 57 again. I installed the fuel tank and started working on the gaps. I had to add 1/8 rod and then grind to the right gap. I still have some spot welding and grinding to do then I can move over to the drivers door.
John Z
62 Barnfind
Old 12-29-2019, 07:55 PM   #15
62 Barnfind
Re: 57 Truck build
Worked in the cowel today and I’m a little closer to getting the gaps right.
John Z
62 Barnfind
Old 12-30-2019, 01:47 AM   #16
Daze57
Daze57's Avatar
Re: 57 Truck build
i agree --- lookin good
Daze57 is offline   Reply With Quote
Old 02-15-2020, 08:28 PM   #17
62 Barnfind
Re: 57 Truck build
Fixed the lower door gap, installed the tailgate and roll pan.
John Z
62 Barnfind
Old 02-16-2020, 09:00 AM   #18
Oldtruckwelder
Oldtruckwelder's Avatar
Re: 57 Truck build
Awesome Build
Great Skills
Keep the progress photos coming
Thanks for sharing
JT from SC
Oldtruckwelder is offline   Reply With Quote
Old 02-16-2020, 12:06 PM   #19
62 Barnfind
Re: 57 Truck build
Originally Posted by Oldtruckwelder View Post
Awesome Build
Great Skills
Thanks for sharing
JT from SC
Thanks! Just when I think I’m getting closer I decide to do something else.
John Z
62 Barnfind
Old 02-17-2020, 05:51 PM   #20
FAKKY
Re: 57 Truck build
dang - done as much as I do in 6 months in 6 weeks.
lol.
When you say " also started adding 3/16 rod to tighten the gaps" --- what does that mean exactly - I can guess …… but then usually Im wrong
FAKKY 57 PANEL BUILD
FAKKY is offline   Reply With Quote
Old 02-19-2020, 08:39 PM   #21
Kevin_C
Re: 57 Truck build
Do you mind sharing what brand fenders and doors you went with? I'm thinking about ordering some but im not sure if any are better than others. I will say your gaps are far better than my factory ones. Nice build
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 02-19-2020, 08:50 PM   #22
62 Barnfind
Re: 57 Truck build
Thanks for the compliment! I had a 20% off coupon with LMC and it’s free shipping over $1000 so that helped on the decision. They fit ok but I had to grind and add metal all the way around the doors and I also added metal on the fenders to get the right gap. I’ll have to do the same on the hood when I get to it. I’m trying to get the lines right all the way around but it takes a bunch of time. A lot of welding and grinding to the right line. The right front fender I bought from Auto metal direct and I actually think it fits better than the LMC one. Hopefully this helps a little.
John Z
62 Barnfind
Old 02-19-2020, 09:11 PM   #23
Kevin_C
Re: 57 Truck build
Thanks I was looking at similar deal with Classic Industries. For what ever reason I have read in several places that the aftermarket passenger side fits better than the drivers side. My truck only came with non fitted fiberglass fenders and I really don't want to reinstall them.
Old 02-20-2020, 10:51 AM   #24
Tempest67
Tempest67's Avatar
Re: 57 Truck build
Wow ! there seem to be a lot of very good metal fabricators on this site, and here is another one.
Thanks for sharing your knowledge, it is a pleasure to see such great workmanship,
stay with the project, and keep the pics coming
Tempest67 is online now   Reply With Quote
Old 02-20-2020, 07:26 PM   #25
62 Barnfind
Re: 57 Truck build
John Z
62 Barnfind
