![]() Join Date: Jan 2018
New Gearset High Pitched Squeal
I put a new R&P (3.42 Excel by Richmond Gears) in and a Auburn Gears Positraction along with a Richmond Gears Install Kit. We measured the backlash many times at .008 and the pattern on the gears we thought matched the picture in the instructions on both sides...maybe slightly toward the outside (heel?) of the ring gear (see pics). The turning force of the pintion once it was installed/sleeve crushed was in spec at 25 inch lbs. At 40 mph I develop a crazy loud ear piercing high speed squeal and it gets worse with speed. We jacked the truck up and it was very noticeable and only changed slightly when let off the accelerator (seemed to be more speed induced). Any thoughts on this would help? Do I need to let the gears break in more?
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
![]() Join Date: Feb 2016
Re: New Gearset High Pitched Squeal
What other new parts were installed?
How much torque does it take to turn the input yoke?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#3 | |
Other parts installed were axle seals/bearings and a chrome diff cover.
Moderator
![]() Join Date: Jun 2017
Stupid question....you did fill it with gear lube after all this work?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
At the body shop.
What's the pattern look like now?
" That didnt make it any newer " " Dont antique the equipment " |
![]() Join Date: Mar 2003
What does the pattern look like on the drive side? From the coast, pinion looks a little deep
It is slightly further in (toward the center of the ring gear), by pinion being deep, do you mean the pattern on the ring gear is a bit far to the outside of the gear? I was slightly concerned it may be a smidge vs the generic picture I was lining up against.
I would suppose the same, have not broke the case and want to get an idea of what may cause a high pitch squeal at speed before I do. I heard the Richmond Excel gears are loud but this you could probably hear for miles so it seems way excessive.
If your pinion depth is wrong, and that will make a load high pitched sound.
Another possibility is you got cheaper gears. I called 3 different manufacturers of these things, and they all said the same story. Gear whine in cheaper sets is very common, and the high end sets something is wrong. The difference is not in the gear forging, but in the quality of the machining as the final process. My 69 Camaro will have gear whine in all likelyhood, but I won't hear it over the 500hp loud exhaust. Problem solved So all is good. |
#10 | |
Sorry I didn't pose the question very well.
#11 | |
Are you thinking the pinion is too tight and eating into the pinion bearing (rather than carrier bearing) or the one directly behind the pinion gear if I am classifying it wrong? We did not go by crush force but rather crushed and spun to measure in lbs on the yoke further and further until it was 25 in lbs.
I would just turn it by hand and see if it takes more effort to turn the yoke than one would expect. There could have been a piece of debris that has ended up in a bearing or you got a bad bearing and this is causing the noise.
I would do a spin check of the wheels too. This is all predicated on the fact you said it was a "crazy loud ear piercing high speed squeal ". Which is not what I would expect to hear from a gear set that was not perfectly set up. An annoying whine yes. A crazy loud ear piercing high speed squeal not so much.
Just going by the single pic you posted, the pinion gear is set too deep (too near the axle centerline).. I think the pinion needs to be moved about .002" or so away from the axle centerline.
Your picture shows the pattern on the coast side.. We need to see both coast side and drive side, so drain the oil, clean the oil residue from the gear teeth, and apply the checking dye to both sides of the ring gear teeth in 4 places.. Remove the axles for this procedure.. Also, you can't check the pinion preload with the axles installed.. |
#15 |
If the marking is further in, then pinion is way too deep. Pattern needs to be as close to center as you can get it. Looks like-- seeing the white marking paste-- that the gears were lapped during polishing. Shoot for that marking. I'm guessing to remove about 6-8 thou and reset the backlash, take another pattern check and post it up.
#16 |
Too deep I assume means remove shims from the pinion to move it further into the case which would move the lap out further from the middle of the ring gear correct? I have a .003" shim on the pinion so I can only move it .003" further into the case by removing this shim. Am I understanding correctly?
#17 |
Yes, but you may have to remove more than 3. But check it anyway
#18 |
I am not sure how to remove more than .003 if that is the only shim I have in it? Here are better pics of the gear pattern.
#19 |
and 1 more
#20 |
I am not a expert, but my gear paste looked like yours. When I took it to a expert to vericate my work. It ended up my lash was also tight.
He reset it, and said I was close. Not bad for a first try. So I will try again in a few months, and hopefully learned from my mistakes. |
#21 |
The plan is to blow it all pack apart, add a .004" shim to the pinion, reset the carrier to get .008" backlash and redo the pattern to send to Richmond. I have been doing some research and quite a few people say the Excel Gears by Richmond are quite loud in general. With that said, the noise this thing made at 40mph is the loudest high pitch squeal I can ever recall hearing...like a bad wind whistle on a leaky door x 1000.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 Last edited by cebra; 11-05-2019 at 01:13 PM. Reason: add content |
#22 |
![]() Join Date: Jul 2016
Your current pattern looks acceptable and moving it a little i dont think is going to make a real difference. I cant think of what else might cause the noise though.
#23 |
On the coast side of the last picture you can see the smooth spot worn into the gears from driving it, do you see that on the other side? Are you sure the backlash was correct and the same all the way around? No Runout? Pattern looks possibly a tad deep into the gear root.
#24 | |
#25 |
Yes check backlash at 4 spots, checking for runout.
Pattern does look good, as far as depth to root, your prob best judge in person, helps sometimes to clean marking compound from root with a q-tip to see if centered. |
