Old 11-04-2019, 09:53 PM   #1
Astro-Balls
Astro-Balls's Avatar
Find My Shift Boot..
Ordered a shift Boot from LMC, and it doesn't fit, its too round and mine is more square. and the holes dont line up on the round one.
Anyone know where I can find one to fit?
Original is on the right.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 11-04-2019, 10:04 PM   #2
72blu
72blu's Avatar
Re: Find My Shift Boot..
I may be wrong but as far as I am aware of the shift boots only came round. There were two variations of the boot, one of them being like the new one in your picture. The other being mounted flat to the hump but still round. It appears someone has cut their own hole in the floor and used a nonfactory boot to cover the hole.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges
1972 SWB Custom 10, gauges, cammed LQ9, M22
72blu is offline   Reply With Quote
Old 11-04-2019, 10:33 PM   #3
davischevy
davischevy's Avatar
I checked GMC Paul's website and they list five different boots.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 11-04-2019, 10:39 PM   #4
Astro-Balls
OK, thanks,
Even if it is a non stock boot, I would like to find a replacement.
Or I can make a Custom Leather boot,... Hmmm, might just do that..
Old 11-04-2019, 10:50 PM   #5
Astro-Balls
I find GMC Pauls a little hard to navigate.. Do they even have a search feature?
Old 11-05-2019, 08:38 AM   #6
yuccales
yuccales's Avatar
Is your trans a NP435? Some Ford sites might have that boot.
yuccales is offline   Reply With Quote
Old 11-05-2019, 09:12 AM   #7
Jason Banks
Jason Banks's Avatar
Fifth item down on this page:
https://gmcpauls.com/rubber&ws1.htm
No picture, $20, says to specify which one you want.
Jason Banks is offline   Reply With Quote
Old 11-05-2019, 10:34 AM   #8
Astro-Balls
GM used the New Process 435 Transmission in limited C20 models, Seems like I have one, and they use a different shift boot.
The shift boot is formed to be taller that the standard 4 speed boot but is formed to fit the floor correctly.
Any Idea where I can find one?
GMC Pauls does not have a picture of the boots available.
Old 11-05-2019, 11:30 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
Paul Jr frequents this site. Send him a PM and have him look at your picture. He should be able to tell you if they have one.
LockDoc
Leon
Old 11-05-2019, 12:38 PM   #10
Astro-Balls
LockDoc
Good Idea, I will try that.
Old 11-05-2019, 01:37 PM   #11
LockDoc
LockDoc's Avatar
Here is one of his threads if you can't find him.
http://67-72chevytrucks.com/vboard/s...d.php?t=791561
LockDoc
Leon
Old 11-05-2019, 01:51 PM   #12
Astro-Balls
Got an email from Sky at GMC Pauls, They don't have the Original boot for my truck but they were very helpful, Still looking.
Old 11-05-2019, 11:31 AM   #13
OregonNed
OregonNed's Avatar
I think a rustic leather boot would look great...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 11-05-2019, 02:52 PM   #14
Astro-Balls
So looking on the original Build Sheet, the truck came with a M28 HD Trans.
SPID says HD 4 SPD CR Trans
Somewhere it was changed to a NP435.
Still trying to find the original boot for the NP435.
Old 11-06-2019, 08:39 AM   #15
yuccales
yuccales's Avatar
Does your SPID & Build Sheet look like these? If so, your 435 may very well be from the factory. Mine is. I found a boot years ago, for a Ford. Still looking for the site and/or a receipt for you. Hope the new one works out.
Old 11-05-2019, 07:07 PM   #16
Astro-Balls
Think I may have found one that will work,
Dorman 924-5405
Old 11-05-2019, 07:50 PM   #17
Mike C
Mike C's Avatar
The NP 435 is the close ratio trans. The M20 SM465 is wide ratio trans.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-09-2019, 04:42 PM   #18
Jrainman
Jrainman's Avatar
The New prosess 435 is not a close ratio trans perhaps you mean the Np 445 witch is a close raito trans .
If you are not happy with that replacment one you found, I would look in to Dodge, since they are pretty much where the first ones to use the New Process 435 , The NP 435 was used in dodge trucks since the early 60s all the way to 93 , So you may have better luck in your search for a OEM one with proper fitment.
Jrainman is offline   Reply With Quote
Old 11-24-2019, 09:29 PM   #19
Mike C
Mike C's Avatar
It is considered a close ratio trans in the GM application. Especially compared to the SM420/SM465. IF you ordered the close ratio truck 4 speed, your got a NP435.
NP435 Four-Speed (Truck)
Type First Gear Second Gear Third Gear Fourth Gear
All 4.78 2.39 1.37 1.00
https://www.onallcylinders.com/2017/...hevy-vehicles/
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-30-2020, 10:52 PM   #20
KevinK7
KevinK7's Avatar
I was linked to this thread since I just came across the same issue. Ironically, my 68 C20 is a 396 4sp just like Astro-Balls, and apparently with the same NP435 transmission as well
From the SPID: "HD 4 SPD CR TRANS"
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 11-05-2019, 11:21 PM   #21
Smitty
Smitty's Avatar
https://www.speedwaymotors.com/shop/...2-20-565-30213
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 11-06-2019, 09:31 AM   #22
Astro-Balls
Yes, My build sheet and SPID are intact and in excellent shape.
Just like yours it says HD 4 SPD CR Trans.
Old 11-06-2019, 09:19 PM   #23
Astro-Balls
Received the Dorman Shift boot today, this thing is STOUT, twice as thick.. Made for a Kenworth Truck..
Fits great with a little elbow grease..
Retainer ring.
Boot Retainer stamp.
Old 11-06-2019, 11:31 PM   #24
LockDoc
LockDoc's Avatar
Good deal! Glad it will work for you.
LockDoc
Leon
Old 11-08-2019, 04:08 PM   #25
Willys_MB
Willys_MB's Avatar
I know it's late, but I just got my transmission back in and dug out my shift boot. Here are some pics of the correct shift boot for an NP435 transmission. It's not in the best shape, but you get the idea.
I hope it at least helps someone else in the future!
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
