11-06-2019, 07:08 AM | #1 |
C20 350/400 to Th700r4
Hi,
I would like to convert my 69er C20 with 350/400 on Th700r4. the th700 comes from a 92 Caprice. what kind of a slip yoke do I need so that the universal joints still fit? Thanks for the help and best regards from Germany I believe in the conversion come up more questions |
11-06-2019, 09:15 AM | #2 |
Re: C20 350/400 to Th700r4
Stock length (5-1/2") slip yoke for GM applications with 1-3/16" x 27-spline output shaft.
Works with 1310 series U-joints. This yoke measures 5-1/2" from tip to centerline of u-joint This yoke is grooved for an "external" u-joint cap retaining clip The machined length on the yoke is 3-3/4" The expressed measurement or length of the slip yoke is taken from the center of the u-joint to tip, not overall. Fits over the output shaft of the following transmissions: Common GM/Saginaw 3 & 4 speed transmissions with a 1-3/16" x 27 spline output shaft Powerglide, T-350, 700R-4, 200R-4, and 4L60 automatic transmissions Muncie M20/M21 and Borg Warner T-5, T-10 & T-56 27-spline manual transmissions For 3-7/32" X 1-1/16" u-joints, to reuse the existing driveshaft you may have to use a combination type of U-Joint. |
11-07-2019, 08:59 AM | #3 |
Thx @YoungPup1977,
then that should be the right one, right? https://www.summitracing.com/parts/hup-hp8801 |
11-07-2019, 09:34 PM | #4 | |
Good luck to you ! |
