Old 11-08-2019, 02:14 PM   #1
msg
Parking brake parts needed for a 66 shortbed
Looking to gather what I'll need for the parking brake re assembly. I kept the cables to match up if needed but the rods are not all there or hangers. Ill keep looking in my stash of mostly organized parts, but assuming I dont find anything more than the rod in the parts pic I took before taking that batch to be sandblasted...whats the punch list for my 66?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 11-08-2019, 02:15 PM   #2
msg
Re: Parking brake parts needed for a 66 shortbed
pic of the cables to replace
Old 11-08-2019, 02:17 PM   #3
msg
pics before I removed everything
Old 11-08-2019, 02:57 PM   #4
msg
A little more digging and I found these, I think this is all I have on the ebrake..except the lever which i have but not pictured. The ubolts were labeled the day I removed them and I cant figure where they would belong in a parking brake system. Do I just start over and buy all new everything? I just want to get the right stuff and everything I need.
Old 11-08-2019, 10:49 PM   #5
Clyde65
Clyde65's Avatar
https://www.lmctruck.com/1960-66-che...g-brake-cables
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-09-2019, 10:48 AM   #6
bigmoe
bigmoe's Avatar
I think the U bolts are for the u joint at the rear end. The cable clamps are not original. I don't see any lever assembly attached to the crossmember. It appears the system has been changed from original.
bigmoe is offline   Reply With Quote
Old 11-09-2019, 04:02 PM   #7
msg
Thanks Clyde and Bigmoe, I looked over the LMC link and compiled a shopping list..about $121 before tax and shipping. Not sure if the intermediate brake cable they have will work with the 700r4 trans real estate. Based on the pics I have posted do you think it will fit?
Also the diagram shows some points where the cable has tension on the front corners. I have the one rod that I think gets the passenger side but what are the other points needing to connect to that I may need to find?
Old 11-09-2019, 06:01 PM   #8
msg
Maybe I wont need to drill, I found this pic I took during the tear down. I assume the bracket that LMC has would bolt in this spot.
Old 11-09-2019, 11:02 PM   #9
bigmoe
bigmoe's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=379268
My 65 looks like post 6 in the above thread. That LMC pic you posted looks like 67-72. I think a lot of people modify their trucks to the newer style so you might be okay with the parts you ordered.
Old 11-11-2019, 09:17 AM   #10
msg
Thanks big moe for this, I found a pic before the tear down and in all that crud looks like the u-bolt.
Old 11-14-2019, 08:37 PM   #11
msg
Well I ordered the parts and right off the bat Im having an issue. The rear cable that clips into the back of the drum plate thats attached to the axle has a much bigger opening than the retaining clip can handle. It just wobbled around and as I pulled back the clip just slid right off the end of the cable. The rear axle may not be from a 66. Ill add some pics to show what Im dealing with. First a comparison of the cable I had before and the one I purchased from LMC. Ill add the item number too in case it helps.
Old 11-14-2019, 08:40 PM   #12
msg
I inserted the cable into its spot there in the back and it had about 1/4 inch play.
Old 11-09-2019, 11:33 PM   #13
Clyde65
Clyde65's Avatar
The 66-72 brake configuration is all the same, it will work fine, I did it on my 65 with a 4l60e.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-10-2019, 09:01 AM   #14
msg
Clyde, what are the 2 lines in that illustration I marked in red..the outermost ones towards the front. It looks like a hanger but its not listed as a part for sale in the diagram?
Old 11-10-2019, 11:28 AM   #15
Clyde65
Clyde65's Avatar
They are hangers, they provide tension to the main cable that makes the loop. When I converted, I was able to get those. Maybe call LMC and discuss??
Clyde65
Rebuild of Clyde
support our troops!
Old 11-14-2019, 09:29 PM   #16
Clyde65
Clyde65's Avatar
Take a look at this
http://67-72chevytrucks.com/vboard/s...d.php?t=770792
Clyde65
Rebuild of Clyde
support our troops!
Old 11-14-2019, 09:40 PM   #17
msg
Im tempted to just return the whole $155 order and clean up what I had. It did work. The boots though, not sure if these can be replaced.
