11-08-2019, 07:16 PM | #1 |
Speedometer Problem Issues
So, this morning was cold, about 20 degrees. nothing to abnormal yet, drove truck to the gas station to get my morning coffee, everything was OK, but the minute I get to the highway(speed limit of 55MPH, but typical speeds are around 60MPH) I realized my speedometer was hovering right around 80MPH, and I hadn't even shifted into OD yet(6.5 Turbo-Diesel with NV4500 and NP208) typical speedometer reading with RPM reading of 2,000RPM is roughly 45MPH,
Also should say here, the Speedometer has always been a little off, I have 31" tires(that are measured at 28.5" actual diameter) and as such without changing the driving gear, my speedometer has been off by roughly +5MPH at 50MPH actual, or a reading of 55MPH so anyways, this evening on the drive home I paid closer attention, it seems like the speedometer reads OK at speedometer readings under 35, but above 35MPH readings, it will read between 15MPH or 25MPH OVER indicated speed, and the needle is a little bouncy, actually it has been a little bouncy right at the 45MPH mark since I've had the truck, but steady otherwise until now. any input is appreciated, Thanks in advance |
11-09-2019, 10:46 PM | #2 |
Re: Speedometer Problem Issues
In my experience with other speedo's, not squarebodies, the oil in your speedo has probably gotten old and its time to send your speedo head off to a rebuilder. it could be the spring inside the speedo has gotten week as well.
11-11-2019, 06:48 PM | #3 |
Moderator
Calibrate it by changing speedometer gears.
The drive and driven gear tables are in the parts books. You need the tire diameter and axle ratio. When a speedometer is properly calibrated you'll find the actual speed is 3mph lower than the reading.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
11-12-2019, 05:41 PM | #4 | |
I did notice, I think Saturday morning, I was hearing some noise from the speedo head, but not 100% sure. No insulation in the cab with a diesel makes many things hard to hear clearly. I actually changed the drive and driven gears in the transfer case last summer(2018) in anticipation of changing tire size, plus it was way off anyways because I went from the stock 305/700r4/np208 to a 6.5/SM465(now NV4500)/NP208, the NP208 behind the SM465 came from a 1 ton truck. I knew I was going to change tires, and so I did the calculations in hopes of not needing to change the drive gear later, just the driven. Needless to say life got in the way and new tires got put on the back burner for now. |
11-12-2019, 06:00 PM | #5 |
little light oil in the speedo cable . they get dry and can make it jump or read funny .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
