Old 11-09-2019, 03:06 PM   #1
elorenzof
steering stabilizer help
Good Morning.
I purchased a steering stabilizer to put on my build, its a 1972 K10. I hope i can explain this correct. On the drag link the hole (red circle) for the stabilizer to mount to is 26" toward the center of the draglink looking directly at the truck going from the passenger side to the driver side. (29" if you measure from the driver side towards the hole going to the passenger side). The bracket on the front axle (Blue circle) is slightly to the right of the hole in the draglink. The draglink adjustment is far to the right on the driver side (green circle) How am i supposed to mount this? Is this the wrong drag link? even if i was to flip the drag link around so the adjustment was on the passenger side ( i dont know if that would even be correct) the stabilizer shock would still not be able to be mounted due to where the placement of the hole (red circle) is. What would you guys do? I purchased this truck half apart so i don't know if this was even the correct drag link.
elorenzof is offline   Reply With Quote
Old 11-09-2019, 03:54 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: steering stabilizer help
The drag link/tie rod and the axle are not from a 72 model year 4wd GM vehicle.
Here’s an example that’s correct for 72: http://www.67-72chevytrucks.com/vboa...9&postcount=57
Old 11-10-2019, 11:00 AM   #3
elorenzof
will my current setup work (just without the steering stabilizer)?
Is a steering stabilizer really needed?
Can i just purchase a different draglink / tie rod setup to add the stabilizer if needed?
Thank you very much for your input and time.
Lorenzo
Old 11-10-2019, 01:35 PM   #4
HO455
HO455's Avatar
I'm sorry I can't answer your questions, but I do suggest that you repost or have a moderator move this thread to the 4x4 section. You will find a larger audience that has had experience with what you are up against.
Good luck.
RIP Bob Parks.
