11-16-2019, 03:29 PM | #1 |
help id engine
Hello all.
New project 65 stepside c10. Removed the engine today and after uncovering engines codes a bit confused. There is A LOT of information out there on engine codes so much so that I am getting conflicting info so I thought I would ask here to se if one of you has this figured out already it is obviously a inline 6.. behind the distributor is con 2 j 2 3 3850817 on the drivers side 17 0817 thanks |
11-16-2019, 06:53 PM | #2 |
Re: help id engine
I'm no expert. Based on an internet search, it looks like the casting number (3850817) is for a 1962-1978 230 or 250. By the date code, the block was cast on October 2 of a year ending in 3, so 63 or 73. So its likely either a 1964 230 or a 1974 250. You need the numbers stamped into the distributor pad to know more.
11-17-2019, 05:12 PM | #3 |
Re: help id engine
thanks for the location. I was looking too far behind the distributor to those larger #'s on the block.
had to scrape the mud away but found FI003NE stamped there. so I believe that means its a 230 from a 63-64 so not the original engine but at least I know what I am working with. |
