11-17-2019, 12:58 PM | #1 |
Installing inner fender well??
I am finally putting my truck back together.
I lowered my truck and my new relocated upper shock mounts now seem to be rubbing on the bottom of the inner fender well. Is this normal ? Do I need to cut the inner fender to accommodate the new mounts or is there another trick I can do to not cut the inner fender? Thanks for the help... |
11-17-2019, 01:21 PM | #2 |
Moderator
Re: Installing inner fender well??
Probably. Do you have a picture of them installed?
11-17-2019, 01:48 PM | #3 |
Thanks for the response... attached is a picture. My husband I are thinking we will grind the top of the mount and add washers behind lower fender mount so I will have clearance around an 1/8” ... thanks, Angie
11-19-2019, 04:15 PM | #4 |
Chevy addict
It doesn't look like you have the rubber bushings in between the inner and the bracket, that would make the difference
11-17-2019, 02:27 PM | #5 |
Moderator
Or find a shorter shock.
Not sure I'd weaken the shock mount though, but that's just me.
11-17-2019, 04:09 PM | #6 |
It's Better With Nitro
Mine is close, but I think my upper mount is located a little closer to the cab.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
11-18-2019, 05:18 PM | #7 |
Can you just bend the lip of the fender a little bit? Or unbolt the bolt in the picture and move that side up a little?
11-18-2019, 11:50 PM | #8 |
60-66 Nut
The correct thing to do would be to trim the bottom edge of the inner fender.
