11-20-2019, 08:10 AM | #1 |
help temp sensor
Im putting a 06 ls 5.3 in my 70 c10 what temp sensor do I need to run stock gauge
11-20-2019, 12:03 PM | #2 | |
The Older Generation
Re: help temp sensor
There are two sensors, one for idiot lights and one for gauges, if you buy a new one be sure you get the right one. I am going to move this to the LSx Swap forum, the guys over there are up on all this stuff. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-20-2019 at 01:01 PM. |
11-21-2019, 11:23 AM | #3 | |
There was someone here taking the old sensors, machining them down, and tapping them for 3/8 NPT. Might be able to do the same with M12.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
11-21-2019, 09:28 PM | #4 |
Might want to check this out - idiot light type I think
https://www.vdo-instruments.com/sens...-801-10-3.html There was also a post about gauge type that has the same resistance as the original but I can't seem to find it. |
11-20-2019, 01:36 PM | #5 |
Yep...just like Leon shows...drill and tap passenger head to the correct npt size the new temp sender is...you'll still need to keep the drivers side LS temp sender for the ecm...
There is a guy on here that was rethreading stock npt temp sensors to metric thread so theyd screw right in the head with no drilling or tapping...I'll look for it...
11-20-2019, 01:49 PM | #6 |
Well ...cant find it at the moment....but if you search temp sender under the LS section,you'll find alot of other options that have been used....again depends on your gauge...but the easiest way is just drill and tap....
11-20-2019, 11:25 PM | #7 |
To use your stock temp gauge you need a Metric to SAE adapter.
Depending on what size coolant temp sender you have, LSX Innovations makes both M12 to 3/8 and 1/2 NPT adapters. Here are the links to the Metric to SAE adapers: M12 to 3/8 NPT - https://www.lsxinnovations.com/produ...apter-fitting/ M12 to 3/8 NPT (Extended) - https://www.lsxinnovations.com/produ...-m12-x-38-npt/ M12 to 1/2 NPT - https://www.lsxinnovations.com/produ...r-m12-x-12npt/ To use an aftermarket electric coolant temp gauge you need a three pin coolant temp sensor. You also need a three wire connector harness to plug into the sensor. For an aftermarket electric coolant temp gauge, you don't need to drill or tap anything. Simply swap out the 2-Pin coolant sensor for the 3-Pin sensor, and then wire up the sensor to your gauge. Here are the part numbers and links to what you need: - 3 Pin Temp Sensor (#12551708): https://www.amazon.com/ACDelco-12551.../dp/B005OVAUN2 - 3 Wire Connector Harness: https://www.amazon.com/Michigan-Moto...RCDHS4PAZDBCYZ
- Snowman 1973 GMC K2500 Sierra Grande Last edited by Cledus Snow; 11-21-2019 at 01:21 AM. |
11-20-2019, 11:38 PM | #8 |
How close does your temperature gauge track with actual engine temperature? I've heard this three-pin F-body sensor gets you functional, but not exact. True or not?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
11-21-2019, 01:16 AM | #9 |
It's close, only off by a few degrees.
- Snowman 1973 GMC K2500 Sierra Grande |
11-20-2019, 11:38 PM | #10 |
cledus...how did you wire that up?...
I should have added to my post above that I'm using mechanical gauges...not electric
11-21-2019, 01:13 AM | #11 |
I messed up, sorry. I updated my post.
