Can you tell me what t-case and trans combo this is?
Cleaning up around here. Got this in a trade a while back, and don't need it.
I've got a '76 Dodge with a granny-4 and NP205, but I can't crawl under the truck to look at the case. I've got a '62 K10 project with a divorced 205, but it's buried under shelves and I can't dig it out to compare. I couldn't find a tag on it, either.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Re: Can you tell me what t-case and trans combo this is?
it is a SM465 transmission with a NP205 transfer case, from a chevy truck
+1. The most bullet-proof combo that you'll find anywhere.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
same info but more .
1984 and older with mech clutch linkage . fig 8 t-case adapter with 10 spline output and input gear . the front output no flat flange makes it a mid70's and older if i recall the dates correct with 10spline output and fixed yoke . good stuff or great parts doner stuff . tag on the np205 t-case would be under the shift rails on the front of the case and 98% are covered in dry oil/dirt mix .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
AWESOME! Thanks guys.
