![]() Join Date: May 2012
hotter spark plugs
I am wanting to put a hotter plug in a 76 farm truck-never gets warmed up to really clean up the plugs. It calls for an AC Delco R44T. I can't locate any R45T locally, but have found some R45TS. The are about 1/8" longer from the tapered seat to the tip. Can anyone tell me it these will work without hitting the piston, or should I just order the R45T and wait? Thank you.
Re: hotter spark plugs
I'm not sure that engine temp correlates to the spark plug heat range. The heat index refers to the insulators ability to pull heat out of the plug itself. Unless you've altered the factory compression ratio, I don't know why you would want a hotter plug?
Guessing the OP is having a carbon problem since the average farm trail doesn't encourage speed driving. Hotter plug might help some. Leaning the idle mix a bit might help also. Plus leaning the choke as much as possible and still get a good cold start. Bumping the initial timing might help as well.
To OP: what motor? |
#4 | |
Give it the 6 ounce tune up!
Dribble some water into the carb at high idle and it’ll clean those plugs off pronto! |
My 83 came with R45TS plugs in the 305 with no problems
![]() Join Date: Dec 2009
Auto-Lite plugs are a good brand for your
application. They work well in a (Also an oil burner) truck that does not see the Hi-way often. I have had Great luck with this. .
Thanks for all of the thoughts and suggestions! Doug
