12-05-2019, 05:27 PM | #1 |
Old member
NSS in auto
Can somebody please look at their wiring harness and tell me where the purple wire comes out of the harness to go to the NSS please?
I'm converting the 68 from a 3 speed to Auto and need to know where the purple wire comes out of the harness to tie into the NSS. Thanks. I know about where to cut it to add the pig tail but would like a closer idea. I only have a short bit of purple wire to use.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-05-2019, 09:09 PM | #2 | |
The Older Generation
Re: NSS in auto
Andy, There are two 12ga purple wires. One comes from the ignition switch to the NSS and it would be hot with the key in the "START" position and the other goes from the NSS to the bulkhead connector on the firewall (behind the fuse box) and from there to the SOL terminal on the starter.... Here is a picture of the Wire loom that they go into. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-05-2019 at 09:22 PM. |
12-05-2019, 10:27 PM | #3 | |
Old member
Re: NSS in auto
I want to know where to cut the large wire to add the NSS into the system.So your saying it goes straight to the NSS switch then into the under dash harness if I'm reading your statement correctly...right.
12-05-2019, 10:46 PM | #4 | |
Re: NSS in auto
LockDoc
12-05-2019, 11:42 PM | #5 | |
Old member
Re: NSS in auto
Thanks, So the pig tail needs to be cut into the wire pretty close to the fuse block then and just ran to the NSS switch. This will keep me from have 2 butt connectors in the line. I can cut the wire into and put spades on each end and call it good.
12-06-2019, 01:08 AM | #6 | |
Re: NSS in auto
Yes, if both ends will reach the NSS. LockDoc
