Old 12-09-2019, 11:46 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Door handles
I was working on my daughters truck today when I had a idea. That's scary thought huh!
Well I been thinking and decided to try it on a old set of handles I have.
The handles have been broke for awhile know. The normal breakage of the button. So I blasted them in the parts blaster. Then I took a wire wheel to the button and the flat on the out side handle.
I'm thinking either body color for the rest of the handle are maybe the Chrome paint in a can you buy. Leave the button and flat as is.
I also blasted the inside door handles and then wire wheeled them also. They will be cleared as is.
I show the button fix next.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-09-2019, 11:51 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Door handles
Here is a trick for fixing broke outside door handles I learned this here a long time ago from jmader post.
http://67-72chevytrucks.com/vboard/s...d.php?t=693760
I have fixed I guess 5-6 pair of handles since I saw it.
You buy a length of 1" square tubing and cut it in 1.5" length's then cut that in half. Pry the handle open enough to insert it and drill 4 rivet holes and rivet it in place. Your done. Your handles will never break again.
Old 12-11-2019, 12:52 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Door handles
Here is a video I did on how to fix the handles.
https://www.youtube.com/watch?v=0kBDwoz9nNo
Old 12-12-2019, 01:05 AM   #4
Astro-Balls
Astro-Balls's Avatar
Re: Door handles
Excellent video, Thanks,
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
