12-11-2019, 04:56 PM | #1 |
GM column swap
OK, give me sh!t if I didn't search far enough but,,,
I need to replace the steering column in my 1980 3/4 ton 4wd manual trans truck. Currently has a non tilt manual column, without cruise. I have a 1980 C10 diesel tilt automatic column, without cruise. I also have a pre-83 tilt automatic column, with cruise. Also have harnesses, if need be. Will the automatic column swap in? Any mods needed? Any/all help appreciated. This is my Daily Driver.
1969 ES5500 B E A S T 1976 K20 Suburban 1983 C10 'farm truck' 1984 K10 Suburban 1988 V30 Fire Truck 1941 Dodge WC18 Ambulance 2000 GMC Bus (parts warehouse) |
12-12-2019, 11:42 AM | #2 |
Moderator
Re: GM column swap
You can use the AT column. The AT lever collar isn't aesthetically pleasing on a MT truck but it will work.
1978-1991 harmonica plugs are the same pinout. 73-77 are different. 1973-1991 Wipers, dimmer, and cruise are separate from the harmonica plug. 73-83 are on the dash and floor. 84-91 have wiper and dimmer switches on the column but you aren't required to use them. The above is only the wiring. You still have to deal with the steering shafts. GM used a splined and a Double D end on the column. I'm not sure what years were what configuration.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-13-2019 at 08:08 AM. |
12-12-2019, 07:43 PM | #3 |
Re: GM column swap
So the manual column is beyond repair?
