12-23-2019, 02:40 AM | #1 |
Hooker Blackheart Engine Swap Motor Mount Kits 12621HKR ??
Anyone use them? Stock bellhousing position?
Eliminating the clam shell mounts would open a bunch of clearence. I want the NV4500 to sit in the exact same position for driveshaft, transmission crossmember, and shifter hole reasons. I am going with a boosted setup and building a turbo log manifold from scratch, but it would make my life a lot easier if I could reuse the factory 10S20F Denson style compressor and mount. It would eliminate any reason to move the battery too. Thanks.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 Last edited by Ford Assassin; 12-26-2019 at 03:39 AM. |
12-26-2019, 03:40 AM | #2 |
Re: Any Tubular Engine Stand/Mount Options??
Bump....
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
12-26-2019, 11:40 AM | #3 |
I was waiting to see if you got any feedback.
I did a x-member sectioning for my old bronze/gold 68 years ago w/a 73-80 x-member as my starting point. When I swapped it between my 68's frame rails after sectioning it, I used a set of tubular style 67-72 engine towers/stands. My set-up required some 1/2" spacers (because the x-member & rails are different between the year models). I would bet they would still just bolt-in for a square. I don't recall specifically where they came from but believe I got them through POL or CPP. A quick google search came up w/this image which is what they looked like but I couldn't find them just glancing @ the POL site....
12-26-2019, 12:18 PM | #4 |
I used 63-72 Tubular Engine Stands for my quick search.
01-04-2020, 02:39 PM | #5 |
I appreciate the reply, I ended up buying Hooker/Holley LS mounts that replace the clam shells altogether. Says they will work with a factory bracket (with some minor triming) and going to use Denso 10S20F compressor (fixed displacement with rear air Tahoe/Suburban/Escalade.
01-04-2020, 04:08 PM | #6 |
mounts - https://www.offroaddesign.com/engine...or-mounts.html
crossmembers - https://www.offroaddesign.com/engine...ossmember.html combo pack - https://www.offroaddesign.com/engine...tor-mount.html ls swap adapters - https://www.offroaddesign.com/engine...er-plates.html or this guy also has stuff mount options with & with out ls stuff - http://diy4x.com/home.php?cat=252 both great places to deal with .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-04-2020, 04:11 PM | #7 | |
01-04-2020, 05:43 PM | #8 |
you never said and nv4500 most guys do them in 4wd .
no problem . i dont see why you cant use the replacement mounts only to swap the clam shell stuff out . call and ask them to see if they will fit . and if ditching floor shifted 4 speed like a sm465 the nv4500 hole will be further back as the top cover is different location . unless you found one for a old box truck setup . here is a 4 speed hump not punched out and the new location of the nv4500 shifter tower is the single boot . all gm parts and locations .
01-05-2020, 09:05 PM | #9 |
I used Dirty Dingo swap mounts for an S10 on the block and built my own tubular stands from there.
I can still count my vehicles on two... wait three hands. |
01-05-2020, 09:16 PM | #10 |
dirty dingo is a rude guy . sold me crappy parts and sent me more crap parts . tried to buy me off to keep my mouth shut but that didnt work for him .
04-15-2020, 02:28 AM | #11 |
Used Hooker mounts....
After hours of modification they do work.
