Old 12-06-2003, 08:21 PM   #1
skokie
skokie's Avatar
valve covers
On one of my valve covers there is the oil hole and what looks to be a breater hole. On the other valve cover there is also a breather hole. Which side should they be installed on?
skokie is offline   Reply With Quote
Old 12-06-2003, 08:48 PM   #2
skokie
skokie's Avatar
This is for a 350 in a 68 chevy,
Forgot that piece of info.
Old 12-06-2003, 08:50 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
My blazer had the 2 hole cover on the drivers side with the oil filler hole in the rear, front hole had the pcv valve running to the base of the carb. Pass side had the 1 hole coverwith the hole in the rear hooked up to the air cleaner...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 12-06-2003, 08:50 PM   #4
jef5150
Inline 69
jef5150's Avatar
are you using a stock air cleaner w/pcv ?
jef5150 is offline   Reply With Quote
Old 12-06-2003, 08:56 PM   #5
skokie
skokie's Avatar
No I am not. I have a pcv valve for it with hose all ready to be connected to the carb.
Old 12-06-2003, 09:19 PM   #6
john
member #16
john's Avatar
If you don't have a hose to the air cleaner, I would put the breather in the rear of pass side cover and the rest as 72 custom camper said
john is offline   Reply With Quote
Old 12-07-2003, 01:39 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hooking the non PCV hose to the air filter has advantages...the air sucked into your crank case will be cleaner, if your getting blow by, then the oil will get sucked into the carb and burned instead of down the side of your pretty engine and chrome valve covers (if aplicable) and keep it off your manifolds/headers.
This is also how some states want to see it run for your state inspection...even if they don't do emissions testing.
However, the breather will work fine, and gets the job done that it needs to do.
Old 12-07-2003, 05:02 AM   #8
jimfulco
I switched the 2-holer to the passenger side (oil hole to the front) on my Nova so it would be easier to get to the oil hole.
jimfulco is offline   Reply With Quote
Old 12-07-2003, 05:10 AM   #9
lukecp
Formerly yellow72custom
lukecp's Avatar
You can always just pull out the breather or PCV to add oil.....i just remove the PCV on my truck to fill her up with fresh Valvoline...
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-08-2003, 04:01 AM   #10
Jemost 72
Southern Bowties
Jemost 72's Avatar
How's this?
1972 Cheyenne 350/350
Jemost 72 is offline   Reply With Quote
Old 12-08-2003, 12:33 PM   #11
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
That's exactly how my new 350 is set up and, as I recall, how most of them are set up. If you swapt them around, the oil fill is located under the A/C compressor.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
