3 Fan Relay + VA - Diagram
What do you guys think? This is how I am planning to wire a trinary switch off my Vintage Air to my 3 relay fan setup.
MDPotter thanks for helping me put this together ![]() ![]() ![]()
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". ![]() |
![]() Join Date: Dec 2012
Re: 3 Fan Relay + VA - Diagram
So the grounded trinary “Blu” has a diode to the high and low side of the pcm so the fans go to high when the trinary switch see’s pressure? And if the pcm tries to turn on the fans it doesn’t change? Will there be any codes in the pcm as the high and low signal wire will see ground when ac is on and the pcm isn’t calling for fans on? I Ask because I can’t remember what I did.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
#3 | |
If PCM turns on fans those diodes are one way only so it won't back feed into trinary. No change. And it's my understanding the resistors plus diodes keep the PCM from seeing ground and stop codes from being thrown. MDPotter showed me this part so I'm hoping we're correct on this. FirstC10, does your setup throw codes?
I have mine setup to kick the high side wire (which will only run 1 fan) so if the motor get above 195 the pcm will initiate the low speed and I will have high speed both fans. I think this is how mine is wired. I never thought about the diodes. I may change mine. No codes so far but haven’t ran it much with the ac on.
I wonder if the A/C is running that I would ever need the low speed trigger from trinary. Chances are the engine already running hot enough low speed is triggered.
PS:. MDPotter has a better diagram. I just modified it on paper to reflect my setup. I didn't think it was my place to post it so maybe he will see this post and put the good stuff on here ![]()
![]() Join Date: Aug 2018
Here it is! I attached it as a PDF so it's easier to download.
Dual Fan GM Schematic w trinary switch incorp.pdf
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
You most likely never would, since in the summer when the AC is generally used, the engine will already be warm enough that the low fan will already be on, with the exception of when you first start it. I've wired several swaps with only the high triggered by the trinary switch and it has worked fine for well over 100k miles on them. That said, it wouldn't hurt to wire both of them up, but just not really a necessity.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
![]() Join Date: Feb 2014
If you are running three relays so that you will have high speed low speed you’re trinary switch only needs to trigger fan 2 which would turn both fans on high. ??
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
This is going to be long-winded.
It is not necessary to wire the trinary into both fans, but I prefer it that way. As Ls1nova71 said, it is rare that there will be a situation where the PCM will not be calling for either fan to come on but the AC pressure will be high and trigger the fan(s), but the OCD in me says to hook up both fans to the switch to guarantee that both fans will run on high when the pressure setpoint is reached. That way, you have both fans pulling across the entire radiator/condenser to lower that pressure. In my mind, that will reduce the risk of damaging any AC components. Here's how my Gen 3 LS works: -Coolant temp reaches around 190 and the PCM grounds out the low speed control wire (green wire, connector C1 pin 42). This wire remains grounded until coolant temp is below 190. Both fans on half speed. -Coolant temp reaches around 205 and the PCM grounds out high speed control wire (dark blue wire, connector C2 pin 33). This wire remains grounded until coolant temp is below 205. Both fans full speed. I found this out while wiring because I was curious. I was able to confirm that both wires have to be grounded in order to have both fans running full speed. If only the high speed control wire is grounded, fan 2 will run full speed and fan 1 will be off. Not a likely scenario, but it's only one more wire to hookup.
Good info here. Potter I'm going to go ahead and wire both like we talked about. I have the diodes and resistors on order. I will report my findings when I test.
#11 | |
Am I thinking correctly here guys? I'm not at a point where I am ready to hook a battery up yet, but very close, so I will test this theory very soon unless ya'll can confirm my thought. ![]()
I have not tried to dissect your drowning but this is how I have have understood the way it works with 3 relays
Low speed turns on relay 1 contact 87 and runs through relay 3 contact 30 in series so that both fans run on 6V When fan 2 is turned on relay 2 switches relay 3 from 87a to 87 witch then grounds both fans and turns off 87a on relay 2 now both fans receive 12V for high speed
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent Last edited by nsb29; 02-01-2020 at 07:38 PM. |
#13 | |
So if for some reason your low speed fans are not triggered by the ECM because engine temps are not high enough, and A/C pressure rises too high for some reason, it's only going to ground/trigger the high speed fan which only grounds relay 2-3. If this is incorrect let me know. ![]()
#14 | |
#15 |
In case you haven't seen this video, check it out, guy does a great job explaining the different relay setups and also demonstrating them.
https://youtu.be/nAKnMl1tK8g ![]() .
#16 |
TA C10, please post updates and lots of pictures...I am currently having issues with the fan controller from entropy and so have decided to get rid of it and wire it with relays. Looks like I'll be following your lead! If you could post a parts list too, that'd be great!
#17 |
I plan on it. I always take a million photos so no worries there. Check out my build thread too soon as I usually put extra detail in over there. I've been out of town lately but hopefully in next 2 weeks I will have more updates.
I have all my relays wired up at this point, last thing to do is wire in the resistors, diodes, and trinary.
#18 | |
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#19 | |
![]() Have you been able to install/test your setup yet? |
#20 |
Ok guys, go check out my build page for extra updates and pictures(post 562, soon I will have a few pics of the fuse box and dist blocks). Basically I have it all wired up now but not tested yet. So stay tuned for that.
But I will post my custom wiring diagram here, you can see the changes I made at the bottom of diagram. After thinking about my fan wiring, I figured out instead of splitting the trinary ground wire close and putting a resistor and diode on each wire separate and connecting to each low and high side trigger connection for the relays, I made the split in wires “after” the resistor and diode so I only needed one. ![]() ![]()
#21 | |
![]() Join Date: Jul 2009
You had it right the first time. Now you've just connected the low and hi triggers together. So, you'll only have high speed (the fans will never come on at half/low speed). |
#22 |
What's the difference from my first diagram and the last? They both hit the low and high triggers via the AC trinary switch. Only difference is I used 1 set of diodes/resistors instead of 2 sets. Right?
This is only the trinary connection. Low and high still get triggered normally by the PCM. I just put resistance on the line so the PCM doesn't see ground when trinary kicks. Let me know if you see a flaw I'm not seeing.
#23 | |
#24 |
Yep, your right, I see it now... Back to original
#25 |
One other thing regarding your 10 amp circuit that you're using for the relay triggers is to make sure that you use an ignition circuit instead of a battery (always on) circuit. It doesn't matter when you're only using the PCM for fan control. But, when you add the trinary switch, it can turn on the fans when the vehicle is off if the coil power is connected directly to the battery. I've wired a few dozen LS swaps over the years and I've personally had 3 or 4 trinary switches go bad and stick shut. That'll activate your fans and run your battery down.
