Old 01-25-2020, 11:17 AM   #1
Crewguy498
Which tilt column to get from junkyard
Which junkyard tilt column do I need to put in the 72?
Crewguy498 is offline   Reply With Quote
Old 01-25-2020, 10:14 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Which tilt column to get from junkyard
72!
Depends on how much work you want to do. I'm sure with some work a 60-70's car tilt would fit in the location.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-25-2020, 11:09 PM   #3
custom10nut
custom10nut's Avatar
Look for old(70-78) RVs in the yard. I’ve happened upon quite a few over the years, and all were in very good shape and were tight.
You’ll have to modify the end shaft and move the wiring connector, but there are plenty of threads on the subject here.
custom10nut is offline   Reply With Quote
Old 01-26-2020, 04:29 AM   #4
clay68c10
clay68c10's Avatar
The boxy RVs from the 70s-80s. Move the NSS and put the flat to round turn signal adapter on and you’re done.
Grab the HD front sway bar while you are there and take a peek underneath for Gear Vendors overdrive.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-26-2020, 10:50 AM   #5
Myself
Good call!!
Myself is offline   Reply With Quote
