Old 01-27-2020, 11:01 AM   #1
1970ChevC10
1970ChevC10's Avatar
1970 C10 Disc Brake Conversion
Is it absolutely necessary to change/upgrade the Master Cylinder when I convert my front drum brakes to disk brakes?
1970ChevC10 is offline   Reply With Quote
Old 01-27-2020, 11:50 AM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1970 C10 Disc Brake Conversion
Simple answer is no you don't but they will never stop the vehicle as they should. Is it the smart thing to do NO! Is it legal no.
The disc brakes use more fluid than the drums do and they will need more fluid as the pads wear down. So in less you like pulling the cap off the master every time before you drive the vehicle It would be best to buy the right one.
The bore of the master will be different also to put more pressure on the brake pads. The Proportioning Valves are different keep the rear wheels from locking up.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-27-2020, 12:25 PM   #3
1970ChevC10
Thanks - much appreciated.
