02-03-2020, 04:40 PM | #1 |
GM ring & pinion
Anyone have a good pic of where the marking for the pinion depth setting is on a original set of gears? They're 3.08 gears from 9/70 (if memory serves correct).
I'll take a pic of the stamping on the pinion, but I didn't really see anything that looks like a setting number. There's a 2-21, but don't think that's it. I didn't notice anything on the gear ring. Thanks. |
02-03-2020, 06:05 PM | #2 |
Re: GM ring & pinion
I have only seen pinion depth numbers on Dana gears. The +or- numbers are on the gear end of pinion.
02-03-2020, 06:54 PM | #3 |
So in this case, am I just doing a lot of trial and error with marking compound, or is there a set standard depending on the ring and pinion number? I assumed each would be different, but maybe not.
If need be, I'll purchase this book if it has measurements: https://www.themotorbookstore.com/di...ir-manual.html |
02-03-2020, 07:40 PM | #4 |
For me it was trial and error. Used the original set of shine to start with. Used marking compound to see where the two meshed together and went from there.
02-03-2020, 08:07 PM | #5 |
GM dealers used a pinion gauge block to get the required shim thickness. No measurement on the gear
02-03-2020, 08:13 PM | #6 |
.035 is where I start if there is no dimension on the pinion gear....if it has the original pinion...start with the same shims that were in it...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
02-04-2020, 12:40 AM | #7 |
I purchased the ring and pinion from a member here on the board. Sadly, it did not come with its original shims.
02-04-2020, 06:38 AM | #8 |
The shim stays with the housing, not the gear
02-04-2020, 03:32 PM | #9 |
02-04-2020, 04:42 PM | #10 |
Even if you knew the + or - for the gear set, its just a starting point, you probably dont even know your housing + or -
Those numbers just help get it done quicker. |
02-04-2020, 08:10 PM | #11 |
Use the shims from the current rear end. It's just a starting point. U can buy a shim kit if needed to complete. This will only b needed to bring backlash n spec and help get enough shim to set pinion. Use your originals first before u order something you may not even need. Keep right and left ring gear shims separate. I put each n a marked zip lock bag. The tool that a previous poster mentioned is a good tool but u can get it done without it.
02-04-2020, 10:58 PM | #12 |
Its a Truck Thing......
I have a 3.07 laying around and I can pull the bearing to see the shim and mike it if you like.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
