Old 02-09-2020, 01:05 PM   #1
03BlkZ
Front disc brakes question
I am in the middle of a restore of my dads 70 short bed C10 and I had questikns about swapping to disc brakes in the front. What I have seen is that the kit from Brothers seems to be a good value as it comes with other front end parts like ball joints, idler and pitman arms etc. What else would I need in order to complete this kit. Also would like to hear from anyone else that has run this kit. Thanks!
https://www.brotherstrucks.com/1963-...tinfo/DBC8L20/
03BlkZ is offline   Reply With Quote
Old 02-09-2020, 09:25 PM   #2
03BlkZ
Re: Front disc brakes question
No one?
Old 02-09-2020, 10:31 PM   #3
67C10Step
67C10Step's Avatar
I’ve looked at the same kit but have not pulled the trigger on anything yet. If you get the kit with the ball joints and tie rods I’d say you would want to replace the cross shafts and bushings upper and lower. I plan to replace my front springs as well.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 02-09-2020, 10:48 PM   #4
custom10nut
custom10nut's Avatar
Look into scarebird, their kit will allow you to keep the 6-lug hubs, and stock spindles.
custom10nut is offline   Reply With Quote
Old 02-09-2020, 10:49 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
I didn't answer because I have a 3/4T and bought a different company's kit. The lower ball joints didn't fit the lower control arms and modifications were required. Also, it's Sunday and maybe people are doing something other than haunting the board. Give it some time for more answers.
~Steven
Simi Valley, CA
Old 02-09-2020, 11:18 PM   #6
03BlkZ
I get it people are busy. I'm used to the corvette forum where you get people responding almost immediately. Thanks!
Old 02-09-2020, 11:40 PM   #7
dmjlambert
dmjlambert's Avatar
You mention having a "70 short bed C10," which is a 1/2 ton truck, and the link to the Brothers kit you gave says it is for 3/4 ton only.
Old 02-09-2020, 11:54 PM   #8
davischevy
davischevy's Avatar
Check out CPP. ECE was my favorite but they closed the doors.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 02-10-2020, 09:26 AM   #9
REDROCKER652002
Can't offer much other than to say that in my experience Brothers has been good to work with. My son's 69 has 71 or 72 parts (Rotors, Calipers, Bearings, Upper Ball joints), and I only know this because that is what we had to replace so far. It has the 6 lug setup and power steering and power brakes. Not sure what else has been changed as we have not had to do anything else as of now, but you might want to try and piece it together using 71 and 72 parts. Might be cheaper than using a kit, but I will admit that the kits are pretty cool, and they have everything you need. Good luck.
REDROCKER652002 is offline   Reply With Quote
Old 02-10-2020, 11:09 AM   #10
Grumpy old man
Grumpy old man's Avatar
Your 70 should use all the same parts I used on my 67 C-10 - 6 lug . All Moog parts from Rock auto and CPP parts from Summit for fast free shipping , If you need all the part #'s I have them and it cost a lot less than anyone offers a "kit " for .
Old 02-10-2020, 03:56 PM   #11
67C10Step
67C10Step's Avatar
Grumpy,
Sent you a PM for that parts list. I was trying to put one together for my 67 and sounds like you have the list I need.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 02-10-2020, 07:59 PM   #12
03BlkZ
Originally Posted by 67C10Step View Post
Grumpy,
Thanks but I don't have any PM's yet.
Old 02-10-2020, 10:40 PM   #13
Grumpy old man
These are the parts I used on my 67 C-10 , Always double check part #'s before ordering .
Moog parts from rock auto
2- Moog upper ball joints - K6023
2- Moog lower ball joints - K6024
1- Moog Pitman arm - K6131 -- Power steering
1- Moog idler arm - K6096T
2- Moog lower control arm shafts - K6147
2- Moog upper control arm shafts - K 6098
2 - Moog tie rods - ES 370R
2- Moog tie rods - ES 350L
2- Moog tie rod sleeves - ES 350S
From Summit
Summit price matches so you can find these parts listed on Ebay and save $$ Ordering Cpp parts thru Summit gets you fast free shipping
1- Classic Performance 2.5" Drop Spindles CP4S2 ( L&R)
1- Classic Performance Upgraded Disc Conversion Rotors CP4R-6 (L&R)
2- Classic Performance Wheel Bearings CP4B
2- Dorman Axle Nuts 4993
For power steering gear I used https://shop.advanceautoparts.com/p/...omer-reviews-d
With a lares coupler (rag joint) https://shop.advanceautoparts.com/p/...rm=201+coupler
order online with Advance discount code and save 25 % and pick it up from your local store
Old 02-10-2020, 06:04 PM   #14
dmjlambert
dmjlambert's Avatar
If you could post the parts list here, I'm sure that will be very valuable information to add to the thread for all of us who are interested to see. Thanks a bunch!
Old 02-10-2020, 11:46 PM   #15
dmjlambert
dmjlambert's Avatar
Great, thanks. Do you know the part number for stock height spindles, and do any other parts need to change if using stock height spindles?
What about calipers? Does this setup use 71-72 calipers, pads, proportioning valve, etc? Do you have a list of these other parts that will be necessary?
Does the existing master cylinder from the drum/drum setup work if it's in good shape, or should that be replaced?
Old 02-11-2020, 12:06 AM   #16
Grumpy old man
Originally Posted by dmjlambert View Post
Great, thanks.
Do you know the part number for stock height spindles ? NO Call CPP
What about calipers? Does this setup use 71 calipers, pads ? YES 1.25 thick
proportioning valve? YES DISC/ DRUM
Do you have a list of these other parts that will be necessary ? NO
Does the existing master cylinder from the drum/drum setup work if it's in good shape ? NO
should that be replaced? YES
Old 02-11-2020, 10:27 AM   #17
dmjlambert
dmjlambert's Avatar
Thanks Grumpy old man, this thread is great!
Old 02-11-2020, 11:01 AM   #18
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Front disc brakes question
Personally I would look at local craigslist are market place for a 71/72 complete front end to swap it into it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-11-2020, 11:41 AM   #19
Grumpy old man
Well . Then your just replacing drum brake junk with disc brake junk that would probably need to be rebuilt / replaced / degreased / painted . All you would be gaining is a set of used disc spindles so no great gain there .
There's something to be said for new parts when your rebuilding steering and brakes .
Old 02-11-2020, 03:35 PM   #20
Andy4639
Old member
Andy4639's Avatar
Question Re: Front disc brakes question
I don't think 71/72 is junk sir. First off he ask for recommendations. Kits are expensive and hard to find ones that work as you your self stated. 71/72 disc front ends are cheap and you get the parts that will work and not have to spend months on hunting parts. I was giving the OP another option. Your comment was not needed at all sir. This board is for info, not to insult people for giving info are their opinions.
If the original parts on these trucks are junk as you say, then why is it there are still so many on the road today with the original parts. Your comment was totally un called for.
Old 02-11-2020, 05:11 PM   #21
Grumpy old man
Andy , Maybe your misunderstanding what I ment by "junk" I wasn't saying 71-72 parts are junk I was trying to convey that 50 year old parts would probably need to be replaced after surviving 50 years on a truck that spent the better part of it's life working as a truck . and not a restored hot rod . Plain and simple we all have our own way of rebuilding these old trucks to suit our own needs . That's it nothing more . I plan on pushing mine to it's limits and within it's capabilities and really wouldn't consider using old steering and brake components to do it . To each their own .
Old 02-11-2020, 12:24 PM   #22
67C10Step
67C10Step's Avatar
Gotta agree with Grumpy on this one. I am replacing all the wear parts in my front end, including the springs. Going with 2 1/2" drop spindles while I am at it but all bushings, ball joints, tie rods, etc. will be new.
I have the spindles, calibers, and entire steering connection from a 73 but when I decided to go with drop spindles it made all that not desirable any longer.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 02-11-2020, 02:21 PM   #23
truck-kid
Thanks Grumpy. Do you have a part # for the backing plates too ? Conversions look so unfinished without them to me.
truck-kid is offline   Reply With Quote
Old 02-11-2020, 02:50 PM   #24
Grumpy old man
Disc brake dust shields came from ebay $39.00 for the pair was the best deal I found on them and the bearing dust caps came from Autozone for a few bucks .
Old 02-11-2020, 03:05 PM   #25
weq92f
weq92f's Avatar
Grumpy,
A little off topic here but...What is your method of painting those rotors and keeping the paint off the friction surfaces?
Thanks,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
