02-12-2020, 01:22 AM | #1 |
planning out dual tank fuel system for LS swap
So im plannin out my fuel system for my 81 c10 6.0 swap.Im tying to retain my factory dual tanks and keep the price low.My plan is to plumb an electric fuel pump into the supply line right after the selector valve to feed a corvette fuel filter/regulator.Would it do any harm to just cap my return line alltogether?this is more then likely just a setup to get it rolling again and im not looking for perfect just funtional.My stock tanks are oem so theres no baffles for intank pumps so thats limiting my options.Ive been looking at alot of different inline pumps and mainly focused on the 255 pump because my setup is bone stock so 350 is right at my target area which wont take much to feed.Thanks any advice/Input much appreciated
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
02-12-2020, 08:26 AM | #2 |
Re: planning out dual tank fuel system for LS swap
The corvette filter/regulator must have a return. On that regulator, the inlet and the outlet are directly connected to each other. The way it regulates the pressure, is by varying the amount of fuel allowed to go out the return outlet. If the pressure drops too low, the return outlet is blocked off. Is the pressure gets too high, the return outlet is opened up.
You will need a six-port selector valve. Three of the ports are switching the fuel inlet, and three of them are switching the return. Also, those inline pumps don't like to suck fuel any distance at all, I'm told. I'd be skeptical about pulling through the selector valve and all associated piping.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
02-12-2020, 03:32 PM | #3 | |
02-12-2020, 05:07 PM | #4 |
This is commonly done, to just use a transfer pump to fill the primary tank from the secondary. If you're doing this, at least one of the factory dash switches('87+ would be the best bet, but some others may work as well) should be fine for operating this transfer pump. I would definitely want an indicator light wired in, so I don't forget the transfer pump is running.
02-12-2020, 09:42 PM | #5 |
I just did dual tanks with 5.3 swap. I have 87' TBI tanks (EFI tanks) with the stock 87' sender, and a EP381 Delco fuel pump which fits right into the spot where the stock 87' pump would fit, but it puts out the needed high psi the LS needs. I have a stock 5.3 fuel regulator on the fuel rail, so I have both the pressure and return lines running to the engine.
I have a new switching valve which is rated for mid-60s psi and it plugs into the stock 87 wiring harness. I replaced all the lines with gates EFI rubber hose from the tanks to the switch valve, and then AN line from the switch to the engine. Lastly I moved the switching valve to the driver side so the lines can run down the driver side of the frame and up to the fuel rail which is on the driver side of my engine. That's not required but its what I did |
02-12-2020, 10:28 PM | #6 | |
02-20-2020, 11:06 AM | #7 | |
chevy truck fan
thanks!! |
02-12-2020, 09:09 AM | #8 |
The tanks from 87 trucks are baffled and are direct replacements. I don't remember if the switching valve is the same as the 81 right off the top of my head but I believe it's the same.
02-12-2020, 11:14 AM | #9 | |
Note that it's for running in-tank pumps with +87+ tanks. |
02-12-2020, 03:27 PM | #10 | |
02-23-2020, 05:49 PM | #11 |
chevy truck fan
ok guys, I am in the process of installing the 381 in/on the '87 sender. I have a few questions - I am not familiar with these pumps/ senders. I would really appreciate some pointers on installing them some of the following:
1- the feeder tube from 381 "butts" against inline with feeder tube from sender? 2- how do the clamps included with the 381 work? 3- the "foam" sleeve included with 381 slips over the elect. conn and hose assy. and butts against rubber sleeve on the top of 381 4- the rubber base sleeve fits the 2 tabs on bottom of 381 which pinches between circular base of sender? 5- the white filter with steel ring slips over the circular bottom portion of 381 the gap between 381tube and sender tube appears to be about 1/8"?? I assume the electric conn to pump is able to be submerged right? what keeps the filter attached to bottom of pump - if that is where it goes? sorry for the silly questions I am just not familiar with these parts before... thank you in advance |
02-23-2020, 09:04 PM | #12 |
This is all from memory - I did this around a year ago so its not super fresh anymore.
1- the feeder tube from 381 "butts" against inline with feeder tube from sender? - I believe they almost will touch, its a bear to get the chunk of hose in there, I believe I slipped the hose on the pump first, and then onto the sender. 2- how do the clamps included with the 381 work? - I did not use those clamps, I think they need some special crimping tool. I got Earls EFI hose clamps for mine, but I think that any EFI rated clamp would do (not a standard worm clamp). 3- the "foam" sleeve included with 381 slips over the elect. conn and hose assy. and butts against rubber sleeve on the top of 381 - I remember putting that foam sleeve on the pump, but not sure on the exact spot it sits. I think mine covered most of the pump exterior. 4- the rubber base sleeve fits the 2 tabs on bottom of 381 which pinches between circular base of sender? I dont recall anymore, sorry. 5- the white filter with steel ring slips over the circular bottom portion of 381 - Yes - the filter will friction fit onto the bottom of the pump. |
02-24-2020, 11:04 AM | #13 |
chevy truck fan
mattchu,
Thank you for the reply... I will redo my clamps.... I will probably go ahead and get the more robust fuel line as well. I mainly wanted to verify that I was "installing" the pump correctly.. as I have no experience in this realm... thanks!! |
