Old 02-23-2020, 08:25 PM   #1
twotrucks
Junior Member
kick panel vent gasket
Looking for recommendation of material to use for kick panel vent. I bought a gasket set through a vendor but the material doesn't seem right. Any recommendations?
twotrucks is offline   Reply With Quote
Old 02-23-2020, 08:31 PM   #2
anew4961
Re: kick panel vent gasket
you can but them from classic parts of america web site they are $3.99 a pair https://www.classicparts.com/
anew4961 is offline   Reply With Quote
Old 02-23-2020, 09:17 PM   #3
twotrucks
Junior Member
anew4961 have you used them? The ones I have bought don't seem to be comparable to the factory material.
Old 02-23-2020, 09:34 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: kick panel vent gasket
I bought the whole vent flapper for the 68. I have also cut inner tubes up to use as the gasket and they seal better than the new ones do and they will not hang up.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-23-2020, 10:54 PM   #5
Grumpy old man
Grumpy old man's Avatar
I just bought some rubber sheet , This ebay seller has it cheap with free shipping and different thicknesses to suit your project , I used it for the flapper vents and as a vibration layer between my rear mounted fuel tank and the frame .
https://www.ebay.com/itm/Neoprene-Ru...YAAOSwlgdaf89j
