Power Steering!!??
SBC power steering pump
with stock steel mount? Picked up a new power steering pump( 20-7920F) as well as bracket pump does not have lower rear mounting stud!?? And all the mounts I've seen (exc my bent to stock steal one) seem to require lower rear mounting stud?? I need either a mount that works With Out Rear Lower Mount Stud Or the same type I have maybe smaller or? and has a Rear Mount Stud mounted lower driver position LWP Last edited by 70cst; 03-07-2020 at 09:13 AM. |
Moderator
![]() ![]() Join Date: Aug 2011
Power Steering!!??
What was the middle thing again?
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by 70cst; 03-07-2020 at 09:13 AM. |
![]() Join Date: Jan 2011
Power Steering!!??
You can put the new guts in your old can. Careful on the colorful language, it is a family oriented site.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic Last edited by 70cst; 03-07-2020 at 09:14 AM. |
Power Steering!!??
if yer that excited over the wrong parts, may want to consider a new hobby..
as for the correct bracket/pump configuration. your application information may lead a board member to a solution for you.. good luck!
I started out with nothing - and I still have most of it Last edited by 70cst; 03-07-2020 at 09:14 AM. |
Power Steering!!??
Not at all Sorry
just slowly replacing stuff on my engine finding out that the parts were just beating up and more used than previously thought I've been wrenching for 30+ yrs we all have those F it moments I ended up taking apart my old pump and noticing that the pump itself has the threads in it to put that mounting bolt so I'm going to have to just drill into the case and put the mounting stud there But again the bracket that I picked up fits too snugly to the pump sides and not enough room to even adjust it if mounted correctly seems that my pump is a little taller than the ones I've seen in all of the pictures metric? my pump to box hose seems to be both flanged And O ring? Last edited by 70cst; 03-07-2020 at 09:14 AM. Reason: misspelling |
#6 | |
Power Steering!!??
Apparently you are working with mismatched parts. Save yourself AND us, a lot of grief, just get the correct pump, and correct bracket, and move on. Last edited by 70cst; 03-07-2020 at 09:15 AM. |
#7 | |
Just here to tinker
![]() Join Date: Jun 2008
Power Steering!!??
I also second keeping the language clean. A lot of great people on this site who are here to help.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 Last edited by 70cst; 03-07-2020 at 09:16 AM. |
Power Steering!!??
Some thoughts.
Unless you've owned the truck since new, you don't know what has been changed over the years. Really inspect old parts before buying new parts. Don't be surprised when things don't fit. I usually go on Rock Auto and look closely at pictures, and options before buying anything. Look for parts for later generations also, they might had been swapped in years ago. You mentioned metric. I think power steering stuff switched to metric sizes about 78ish. Might look for the hoses you have to figure out the pump you have. If you need brackets, I would look at Summit
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z Last edited by 70cst; 03-07-2020 at 09:15 AM. |
Power Steering!!??
Having to deal with my son's 69 and it's mismatched parts, I feel your pain. Keep at it, and relax. Have a beer, take a deep breath and post away. Somebody here is gonna be able to help you out. My son's front brake setup was from a 72, his heater in the cab was from who knows where. LOL. That is part of the fun of dealing with an old truck that you have no idea where it came from. Take it slow, enjoy the ride and relax man. Have a beer, don't cost nuthing. LOL
![]() Join Date: Sep 2014
Power Steering!!??
Can the mod change the title of the thread?
Power Steering!!??
I myself curse nonstop but its NOT needed here!!!!
Moderator
Power Steering!!??
Same here (as you can imagine). One of things I like about this site.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by 70cst; 03-07-2020 at 09:17 AM. |
Power Steering!!??
He didn't curse. He just vented. LOL. I think the symbol thing has been used for ever, so let's just relax folks. We are all adults here. Again, have a beer, don't cost nuthin. LOL
![]() Join Date: Feb 2001
Re: Power Steering!!??
This tittle is not acceptable ... these forums are geared towards a family oriented site.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#15 |
![]() Join Date: Oct 2006
Power Steering!!??
I thought he was taking about a Mount Franklin power steering pump......
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by 70cst; 03-07-2020 at 09:17 AM. |
#16 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Power Steering!!??
Stinky poo poo boogger eating tissue wipe!
I am so mad!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by 70cst; 03-07-2020 at 09:17 AM. |
#17 | |
#18 | |
That's how grown-ups talk.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 03-07-2020 at 09:23 PM. |
#19 |
If you start letting good manners slide, foul language eventually turns into personal insults....I've seen it on other forums while researching various projects. I appreciate the fact that the rules are enforced around here.
