Old 03-08-2020, 12:26 PM   #1
Ricks1971
Ricks1971's Avatar
1967 disc brake master cylinder options?
I have a 1967 C10 which I converted to disc brake front brakes. I have a big cam in the truck and the brake booster doses not stop the truck very well. I have seen several truck with disc/drum setups and the were using no brake boosters just a master cylinder. I was told all you need is just a corvette master cylinder with out a brake booster. What master cylinder in this setuo are you guys using? thanks Rick
Ricks1971 is offline   Reply With Quote
Old 03-08-2020, 10:47 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 1967 disc brake master cylinder options?
I would use hydroboost..my 2 cents
If you want to run no booster at all then you'll need a disc/drum master cyl...I'd call cpp, tell them what you have and want...they'll hook you up..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-12-2020, 07:34 AM   #3
slolowtaco
Wilwood tandem. Works great.
slolowtaco is offline   Reply With Quote
Old 03-12-2020, 11:12 PM   #4
Ricks1971
Ricks1971's Avatar
I am going with the wildwood master cylinder thanks guys
Old 03-16-2020, 10:07 AM   #5
SCOTI
SCOTI's Avatar
Non power disc set-ups should have a smaller bore size vs. a system w/a 'booster'. If not, the pedal may not produce adequate line pressure. Just swapping in a different master cylinder w/o making sure it's correct is like flipping a coin when spending money.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
