Old 12-09-2003, 12:07 AM   #1
84Stepper
84Stepper's Avatar
Angry Lowered front wheel alignment problems
Here's the problem, my front wheels keep going out of alignment bad! The wheels are toed out at the bottom real bad. They look broken and the truck pulls hard to the right. Took it to the alignment shop for the 2nd time and he said he shimed it all he could but told me it would not stay. Said I needed a custom control arm or something to correct the problem I created and said it would be big bucks to fix.
Here's what I did: lowered the front with Western C 3" lowering springs and Doetch shocks. Threw the original springs out. Probably should of used spindles and 1" drop springs. What can I do to correct the problem before it goes out again. Thanks!
84 Chevy Stepside, 350, TH350, 268h
Comp cam, Hooker headers, MSD
Pro Billet, Edelbrock Performer manifold
and 1604 carb, 40 Series Flowmasters
dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi
84Stepper is offline   Reply With Quote
Old 12-09-2003, 12:53 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb
What you need to do is unbolt the upper A-arm and knock the tie bolts out of the frame and install 2" longer one's and install a 1/2" spacer between the frame and cross shaft put it back togeather leave all the shims out and take it to the alignment shop and now he should be able to have enough adjustment now.
Or go buy some drop spindles and be done with it.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 12-09-2003, 10:25 AM   #3
gldevall
gldevall's Avatar
I'd say 1st thing take it another alignment shop. Was the place you took it to any good? There are several around here that do alignments and they suck big time. Then there is this one place that is all they do is front end work and they stay busy....probably fixing the sh!t form these other shops. LOL
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 12-09-2003, 04:21 PM   #4
87 STEPPER
87 STEPPER's Avatar
Lightbulb
You can try what gldevall sugested but another shop will probably tell you the same thing.
In '85 i lowered my '85 stepper this way only because droped spindles wern't out yet and the kit i got gave you longer bolts for the upper control arms and a 1/2" thick spacer and i had to cut a few coils off my factory spring's that was considered a front drop kit back then. cuz droped springs wern't around then either anyway's you have to move the upper control arm back outward's to compensate for the shorter spring and bring the suspsnsion geometry as close to the factory spec's as possible that's why the aligment dude told you he cant install any more shim's.
This is a very crude way of lowering and i wouldn't reccomend it at all. Most people use a droped spring with a droped spindle. And not by it's self and never encounter this problem.
I know you may not be able to afford spindles but that's what you really need to do to fix the truck.
Another thing when i had my '85 lowered that way i was going thru lower A-frames like crazy due to the suspension not being able to clear manhole cover's.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 12-09-2003, 05:51 PM   #5
Izzy
Trucker.
Izzy's Avatar
I'm with 87stepper or if you can't do that get some DJM UCA's they give a couple extra degrees for the caster/camber.
Izzy is offline   Reply With Quote
Old 12-09-2003, 06:04 PM   #6
swervin ervin
You get what you pay for
swervin ervin's Avatar
They also make offset upper control arm shafts. On mine, with 2.5 spindles and 1.5 springs, my alignment guy told me I needed the offset shafts. My alignment is perfect, but I couldn't go lower without doing something else. I don't have enough bolt left.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 12-09-2003, 10:21 PM   #7
84Stepper
84Stepper's Avatar
Ok, sounds like the answer is to put in the spindles. Question...I really don't want the front to go much lower than 3" or 4", but that's about it. I've got the 3" lowered springs in now SO WHAT SIZE SPINDLES do I get that can fix the problem? Is there something I can do to raise the springs to help? I definately can't do the 2.5" like Swervin. Hey Swervin, what about those offset upper control arm shafts, where do I price them and would that fix my problem any easier?
Old 12-09-2003, 10:38 PM   #8
swervin ervin
Advance Auto Parts sells them.
http://www.partsamerica.com/SelectPa...+Chassis+Parts
Yes, they are supposed to fix your problem. I've never used them, just going by what my front end man told me. And this guy knows his stuff. They're not cheap though.
