Old 03-11-2020, 11:15 PM   #1
Hair
454 Flexplate question
71 GMC with Inline 6 and power-glide tranny - I pulled the I6 and put in a 1989 454 from an RV. I have not started the engine yet, still waiting on a carb and a starter. The flex plate on the 454 would not bolt to the torque converter on the power-glide, so I just used the flex plate that was on the I6. But now I've learned that the 454 is externally balanced and uses a special flex plate.
Here are my questions:
1. Do I need to take the I6 Flex plate off and get the correct flex plate?
2. What will happen if I run the I6 Flex plate?
3. Can I buy a 454 flex plate with a hole pattern that will fit the PG torque converter?
4. Will a 454 flex plate fit in the bell housing of the PG?
Hair is offline   Reply With Quote
Old 03-12-2020, 12:51 AM   #2
kwmech
Re: 454 Flexplate question
Yes you do.
It will create an engine vibration being out of balance.
A new 454 plate from Summit should have a dual bolt pattern
It should clear but if it does rub, minor grinding can make it clear the aluminum nubs inside the bell
kwmech is online now   Reply With Quote
Old 03-12-2020, 09:16 AM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
If you run it with 6 cyl flex. You will shake the main and thrust bearings out of it in minutes. Probably ruin pump in the trans too.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 03-12-2020, 01:47 PM   #4
MARKDTN
Agree. 400SB and 454 have unique flywheels/flexplates. You do not want to run external balance style on them.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-12-2020, 02:30 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Don't they make a separate bolt on balancer plate that will compensate for that?
LockDoc
Leon
Old 03-12-2020, 10:20 AM   #6
Hair
Ole Blue,
Within minutes??!! You got to be messing with me? I figured it would cause issues over time? If you're serious, I'm glad I haven't tried to fire it up!
Old 03-12-2020, 04:46 PM   #7
68Gold/white
Originally Posted by Hair View Post
Ole Blue,
I've heard of this "mistake" by a couple of shade tree mechanics...had to start all over again with build...
Concerning the good olden days of Chevrolet V-8 engines, the largest displacements of the small block (400) and the big block (454) were externally balanced at the harmonic dampener and at the fly wheel/flex plate, AND I believe the 454 and 400 fly wheels are different..
There's nothing to buy to add to a neutral balanced flywheel... A person COULD have a weight added to a neutral balanced flywheel. It would have to be the exact precise weight and in the exact precise location...all this would cost more than buying the correct needed fly wheel/flexplate...
68Gold/white is offline   Reply With Quote
Old 03-13-2020, 07:33 AM   #8
Mike C
Mike C's Avatar
Most aftermarket flexplates are dual drilled for both patterns. $60 gets you an SFI certified one from Summit, Jegs, Amazon, etc. that is externally balanced for your 454.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-12-2020, 01:00 PM   #9
Ol Blue K20
It took about 10 minutes to screw up a fresh small block 400 / turbo 350.
Dale
Old 03-12-2020, 03:28 PM   #10
Wrenchbender Ret
If they are the same diameter, drill holes in the 454 plate to match the converter.
It will have a horrible vibration if you use it.
I had a customer onetime that had put a sb400 plate on a 350. It didn't damage anything but had a bad vibration. I went up through the opening on the bottom & knocked the weight off. It saved tearing it down & worked fine.
Wrenchbender Ret is offline   Reply With Quote
