![]() Join Date: Mar 2020
Identifying frame year
Hey all,
I’m trying to figure out what year my frame is. This is all I could find, it’s stamped upside down on the passenger side frame rail. I rotated the picture for viewing. There’s no marking near the steering pump as i thought there was for the 2nd gen. So I think maybe a 73-87 frame? Any idea? Thanks |
Re: Identifying frame year
Is there a partial vin starting with a C or a T on top of the frame rail?
All 73 and up will have leaf springs. 73 and later frames will have the brackets or marks were the brackets were for the gas tank (s) too. Remember that 1/2 ton GMC 67/72 were usually leaf spring if you are going by rear springs.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 03-22-2020 at 04:22 AM. |
#3 | |
What year is your truck?
Your frame looks exactly like my '70 frame. |
![]() Join Date: Feb 2009
3987562 was replaced by a subsequent part # December 1971. Your frame would then be early model 72 I'm guessing. 4 22- Date code?
It's that or I'm reading it backwards, I don't recall that stamp on my 71. Either way it's period correct. Your VIN is probably stamped as mentioned. Mine is in two places. I can't check, but one near the transmission cross member. I think the other is forward the firewall. Both are on top of the LH frame rail.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-22-2020 at 11:53 AM. |
#7 | |
You'd need a mirror to see the one behind the transmission cross member. I can't check the one in front, because the frame is wrapped up. The front stamp may be underneath the cab, but I thought it was forward the firewall. I don't see it on my other truck (72 C-20).
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
All about them K’s
![]() Join Date: Jun 2014
Driver side top of the frame rail should have a partial vin number stamped right under the cab as well as the top of the frame by the steering box if it’s a 72 frame. Earlier trucks especially GMC are known to not have vins by the steering box. Not sure if the earlier trucks had the stamp under the cab or not. My 72 K20 did. You will have to lift the cab to see the vin under it. But the other by the steering box is pretty easily seen if the frame is clean.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 03-22-2020 at 12:10 PM. |
#10 | |
All about them K’s
Any chance the paint is pretty thick and covering it over? The stamping on mine is legible but not that deep. Initially I had to wire wheel the frame to find it.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#12 | |
Not willing to scratch the nice paint to look for it at this point haha |
All about them K’s
I totally understand. I was prepping mine for Fresh paint. Could certainly be you’ve got an older frame or maybe even for one reason or another yours is original and just didn’t get a vin stamp. Hard to tell for sure after all these years.
