03-25-2020, 04:08 PM | #1 |
Inner fender mounting bracket
Anyone know where to get this part?
03-25-2020, 04:13 PM | #2 |
Re: Inner fender mounting bracket
its for mounting the inner fender bracket to the cab....no one seems to have them? 56 truck
03-25-2020, 09:44 PM | #3 |
If its just that stud broken you can just weld a bolt in or just drill that side out an use a bolt straight through. Carpet would cover it. Im thinking there will be more brackets for sale than the mounting plate itself.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90 http://67-72chevytrucks.com/vboard/s...d.php?t=746958 |
03-25-2020, 10:21 PM | #4 |
most likely what I will be doing
03-25-2020, 10:32 PM | #5 |
I looked through a few catalogs, doesn't look like its reproduced.
03-26-2020, 03:15 AM | #6 |
I would just hammer the old studs out or drill, whatever. then use a couple of carriage bolts in their place. bolt the parts together tight and then tack weld the bolt heads to the plate. use a little seam sealer on the plate so water doesn't get through to the inside of the cab.
03-27-2020, 08:35 PM | #7 |
Drill out and use 5/16 elevator bolts.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
03-27-2020, 10:03 PM | #8 |
these work too. elevator bolts.
https://www.homedepot.com/p/Hillman-...1005/202242421 |
