rim ?
On these 15 x10 wheels I have, they have 4" of BS. Am I gonna run into problems putting these on? I have been told that I should run a 28 X 12.5 ET street on these. Is this tire gonna rub? Or is this gonna be a trial and error issue? I have about a 6" drop in the back.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
trial and error if nobody here knows, but atleast if you try it.. you can tell us all if it works!
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
they will probly rub your the outside of your rear fender because of your 6 inch drop. if it was stock height they would fit fine.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
i'm running 9½"x17" rims out back with 5" of drop, and I could go lower the the tires would tuck in just fine...but I have 5½" of Backspacing
How about a 26 X 11.5 X 15
#6 | |
#7 | |
Re: rim ?
thats the problem. there might be a short and not so wide tire that you could put on there that would make it work, but really the rims are just the wrong size. the only way your gonna figure out what will work on those rims ia some careful measuring or guess and check which could get expensive ![]()
So I need to get rid of those and get a 15X8
You can still run a 15x10, you just need the correct back spacing, i think to run a 10 out back it would be 5" im running a 20x10 out back with a 6 inch backspacing and it tucks alot..
85 swb, 5/7, 20" smoothie 2's |
You get what you pay for
![]() Join Date: Dec 1999
Stock, the wheels stick out 1" farther up front than they do at the back. When you drop it with springs, it pushes it out even further because of all the shims that needs to be used to get the camber back right.
Anyway, with a 10" wheel, you would need 6" of back spacing in order to be the same as stock. So, you can figure our stock 8" wheels came with 4 and if you use a 10 wheel with 4, you are going to sticking out 2" further than stock. I think I would go with a 10" wheel but with 5" of back spacing. But if you have some tires mounted on 8" wheels, measure how much room you have left at the fender. Then add 2" to this to see where it is at. |
That's the problem, the wheels I have I bought from a clearance sale at Summit for $40 (total). I 'm gonna see if I can return them and get some 8" wheels. Cause I am not raising the rear end back up.
