03-31-2020, 02:09 PM | #1 |
Door locks only when open and on 1st latch
I've never been able to lock the driver's door believing the problem to be a poorly installed after market central locking actuator.
Today I removed that and found: 1) Locking works fine when the door is open; 2) Locking works fine when on the first latch; 3) Does not want to lock when on the 2nd latch. I've oiled everything and everywhere and I've adjusted the pillar catch. No lock luck. Is there a known issue that could be causing my problem?
Best regards, Philip Chev: '70 C10 (350 V8 / 700R4 ) & '59 Apache ( 235, 3-sp ) Jensen Interceptor '74: Mopar 440(EFI'ed) / 4L60e Jaguar: '72 E-type Coupe V12 & '74 E-type V12 Convertible & '80 XJS V12 |
03-31-2020, 03:01 PM | #2 |
Re: Door locks only when open and on 1st latch
Since our trucks didn't come with power locks there probably isn't a known issue. That being said the fact that it is the drivers side leads me to surmise that 50 years of wear have introduced play in the mechanism that the passenger side doesn't have. (Which is a known issue) I suggest finding a way to view the mechanism while operating and compare the two sides carefully. Maybe one of them newfangled cellular phones would help. I think you will find too much play on the drivers side mechanism. I also suggest searching "door lock problem " in the search box above to help get an idea what you should be looking to find.
Good luck
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-31-2020, 03:49 PM | #3 |
Latch assembly is worn.... replace. I had the same problem and thought it was the locking assembly mechanics but was told it was a worn latch so I replaced it and problem solved.
I might and you may want to try, I could lock it if I pushed/jarred the door in while turning the key at the same time. |
04-01-2020, 04:07 AM | #4 | |
Pressing on the door results in the toothed gear rotating "forward" just a wee little bit, enough to allow the lock latch to engage.
03-31-2020, 05:33 PM | #5 |
Seems like a common issue from what I have seen. You have to put pressure on the door as you turn the key to lock. I adjusted the strike plate on the body side out just a tiny bit and it helped some. Just a little extra push now on the door and it locks fairly easy.
72 Cheyenne Super swb |
03-31-2020, 08:32 PM | #6 |
Read my door locking problem thread, there is a link to it in my signature line.
You need a new door latch, the repro latches work good. |
04-01-2020, 09:36 AM | #7 |
I found the toothed gears centre pin gets worn enough on the housing to let the gear twist out of alignment.
04-01-2020, 10:01 AM | #8 |
Mine has some wear on that pin but it did not SEEM enough to be causing the problem. Can only be sure if I remove the entire mechanism, but since I now have a solution, not a high priority.
