Old 04-01-2020, 09:38 AM   #1
custom10nut
custom10nut's Avatar
Replacing the “Fuel Sock”?
Here’s a thought that just came to mind.
How does one go about replacing the “Fuel Sock” in a stock in cab gas tank?
And another question is, where would I get one?
Do you just go in through the top front of the tank, where the fuel line comes out?
I just saw a FB post, and the guy shows on picture of the remnants of his, with the caption “well it lasted 49 years”.
In my 70, I’ve never replaced mine. And to my knowledge it’s still the original.
If it’s a good idea to replace it, I’m gonna, so I don’t get stranded somewhere someday.
custom10nut is offline   Reply With Quote
Old 04-01-2020, 09:53 AM   #2
raggedjim
raggedjim's Avatar
Re: Replacing the “Fuel Sock”?
Here's one, a google search brings back others. I got one when I had to replace my sending unit.
Rg
https://www.americanclassic.com/1967...CABEgI0_fD_BwE
raggedjim is offline   Reply With Quote
Old 04-01-2020, 10:01 AM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I got mine from here: https://www.fillingstation.com/
You just need to remove the sending unit/fuel pick up, and its right there on the end of the pick up. Easy to install, just a pain in the butt to get to.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-01-2020, 10:05 AM   #4
rpmerf
rpmerf's Avatar
Rock auto calls it a Fuel Pump Strainer
https://www.rockauto.com/en/catalog/...+strainer,6212
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 04-01-2020, 11:29 AM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I replaced the sender with a new one. The sender came with the sock.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 04-01-2020, 02:56 PM   #6
steves1967
steves1967's Avatar
Hey, that was me! I bought a new sending unit for the truck, then I bought the Tanks, Inc adapter and dropped an electric pump into the stock tank! Now I'm ready for the L31 350 engine, or the 496BB, or and LS swap!
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 04-02-2020, 06:33 AM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
While we are talking about gas tanks is the actual sending unit still available for our trucks. I looked on Rock Auto and didn't see one listed.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-02-2020, 09:56 AM   #8
raggedjim
raggedjim's Avatar
They are available, Rockauto doesn't list them though, not sure why.
Old 04-02-2020, 09:01 AM   #9
SwitchbladeII
Good idea to replace, I replaced one in my last project and it came apart in my hand when I removed it. There are two sizes available 3/8" and 5/16" so I would check the tube before ordering, mine was a 5/16" and got a 5/16" but it was still a little loose so I had to do a little crimping to get it tight. If I remember right the remnants of the of the metal ring didn't come loose easily. Removal of sender is easy as stated in other post.
SwitchbladeII is offline   Reply With Quote
Old 04-02-2020, 12:48 PM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
If you want to replace full unit, I have a complete fuel sending unit I pulled from my in cab tank-used for 3k miles.
Be glad to sell to you $10 + shipping. I will put in truck parts forum with pictures and give you 1st dibs.
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-02-2020, 02:54 PM   #11
SRU1436
I literally just replaced my fuel sock last week. Mine had the original one which basically disintegrated. I had the clean the remnants from inside the tank.
SRU1436 is offline   Reply With Quote
Old 04-06-2020, 12:20 PM   #12
Lee H
Lee H's Avatar
I replaced the sock in 2013 as part of my frame off, no sure where I got it. About four months ago I had the carb rebuilt and the rebuilder told me there was a little debris in the bowls, check your filter. I opened it up, Russell 40 microns, and it was full of fine particles, I cleaned it out and replaced it. I pulled the sending unit to check the tank, the sock was mostly gone, I removed what was left and replaced the sending unit. I opened the filter again last week and its about 1/4 full again. Here's a picture with a coin to judge the particle size.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-06-2020, 03:51 PM   #13
raggedjim
raggedjim's Avatar
What is it? Is it magnetic?
Old 04-07-2020, 09:23 AM   #14
Lee H
Lee H's Avatar
That is the debris from inside the fuel filter. I suspect it's the remnants of the sock. Not magnetic.
Old 04-07-2020, 10:33 AM   #15
fdbdw
fdbdw's Avatar
I had same issue in my last truck, clogged the fuel pump, filter and made its way to the carb. I would clean them out and it would reappear, took me for ever to figure out what it was. It’s an easy replacement and should be at the top of the “ to do list” if it’s never been done.
fdbdw is offline   Reply With Quote
Old 04-07-2020, 03:31 PM   #16
DennisP
DennisP's Avatar
Had the same problem with mine a few rears back. The sock had completely disintegrated . After the P.I.T.A. of cleaning out the tank, I installed a in line fuel filter under the cab where the fuel line comes out of the tank, and did not replace the pickup sock. Can't remember exactly, but I think I got this tip from someone on here.
DennisP is offline   Reply With Quote
