Will Corvette 454/427 exhaust manifolds fit 1968-1970 Chevy C10
I am looking to run cast iron manifolds on a 454 that is going in my 1968 Chevy C10 which is a original 396 bigblock with 400 turbo truck.
Will the 1968-1972 Corvette 454/427 exhaust manifolds fit on these trucks or do they run into really bad interference? I was hoping to buy a set of those Dorman Corvette exhaust manifolds as they are affordable but I am unsure if they would fit. I am not sure what the original 396 exhaust manifolds looked like on 1968 Chevy C10 shortbeds as my original engine has headers currently. I dont know what happened to the manifolds as they were missing when i purchased it and they are probably hard to find anyways and I have not found any reproductions of the truck manifolds. Last edited by HeavyHauler; 04-02-2020 at 10:27 AM. |
![]() Join Date: Jul 2016
Re: Will Corvette 454/427 exhaust manifolds fit 1968-1970 Chevy C10
Im pretty sure they reproduce the truck manifolds.
They are very common manifolds that also fit big cars i think, basically same up to the 1980’s, anyway easy to get on the parts forum. The left side corvette manifold fits good. The right side corvette manifold hits the frame and would need a large piece of the lower rail removed to fit. I dont think its practical or safe to make it fit |
As far as factory reproduction exhaust manifolds I can only find one company that wants $500 a set for a set that will fit a 1968 Chevy C10 with bigblock. I was wanting something a little more affordable if I am going cast iron.
Another company only makes the passenger side exhaust manifold but they are reasonable with the price. Anybody have a source? |
Rockauto, $85 and $115
https://www.rockauto.com/en/catalog/...+manifold,5860 |
#5 | |
When i post something you can count in it being correct.
All year big block manifolds are the same. |
#7 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
ATP 101065 {#10045732, 12551443, M327164} $114 Right ![]()
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#8 | |
Keep on point here! The question is what manifolds fit 68-72 big block trucks. They are all the same. Again When i post something you can count on it being correct. |
At the body shop.
I have a pair of squarebody exhaust manifolds you have for the ride. For a test fit
" That didnt make it any newer " " Dont antique the equipment " |
I was looking at Corvette exhaust manifolds because it seems they would offer a little better exhaust flow.
![]() Join Date: Jan 2002
They may flow a little better but not worth the frame modification. Just get headers if you want a lot of flow. Or if you want manifolds, as posted above, all passenger cars and trucks used the same basic manifolds. Pay $25 to become a subscribing member and post a want to buy ad. Big block manifolds are NOT hard to find
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
I have already purchased the Corvette manifolds for my '69 when I swap the 427 in. I am expecting to trim the frame and possibly angle mill the manifold a couple of degrees. It's still off in the future, but I really want the 'vette manifolds and am willing to put the work in.
![]() ![]() Join Date: Sep 2008
I have 71 Corvette manifolds and 71 Truck manifolds laying side by side and I can't imagine how the Corvette manifolds could flow any better.
It appears to me the only reason for design difference is a matter of clearance on the right side.
To my eye the Corvette big block manifolds will flow better. They have more volume and the front ports hit the exit sooner and turns are much better streamlined. Looks aren't everything, but GM went to the trouble. And I am going to as well. Will see if that was worth the trouble. LOL
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 04-04-2020 at 09:27 AM. |
#15 |
![]() Join Date: May 2004
please update as you can... will eventually installing a 454 into my burb and wanted to go this route also instead of headers....
#16 |
I was thinking the same as the poster who stated if you want better flow buy headers. I don't know too much about BB, but I don't see where there would be all that much difference if you are not putting together a race motor or high output motor. I would be very very VERY cautious about cutting into the frame. That is the base of the truck, and if you are using a big block with any kind of torque you run the risk of twisting up that frame, then you are in a whole lot of trouble. Just my opinion, and I am a weekend warrior at best, so take it for what it is worth. RR
#17 |
It's just a matter of clearancing a little of the top rail, not major surgery.
#18 | |
Good luck with the project. If my son was a bit older and more experienced, I would suggest a BB for his truck. But giving a 19yo boy that much motor is just not the best idea LOL. I know what I was like at 19. Last edited by REDROCKER652002; 04-06-2020 at 12:37 AM. |
#19 |
I have a 1969 L-36 from a Corvette that has been restored externally and modified internally for my 1969 short bed. The goal is to make it look like it was installed that way from the factory and that includes the big block Corvette manifolds.
For me, the manifolds are an important part of what I am going for. If they won't work without significant mods to the truck, I won't do it. I already have a REALLY expensive set of Sanderson big block iron manifolds, but they are not what I want. And I am willing to put in the time/effort/expense to make this work. Most likely a few degree angle milling and spot facing the bolt heads will provide sufficient clearance. If not, removing 1/4"-3/8" of the upper frame rail will not drastically alter the twisting resistance of the frame.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 04-06-2020 at 11:00 AM. Reason: Changed billing to milling. |
#20 |
Yeah definitely not wanting to do any type of grinding or cutting on my frame at all. It is interesting that you would have the same exhaust manifolds on a 1970 Chevelle SS 454 as you would a 1972 Chevy C10 PU with 402. Guess I have a choice to make. Thanks for all the info guys!
