How did you remount your bed?
I’m pretty much done redoing my bed wood. Now I’m looking at how to get the bed back up on the frame? I’m thinking of doing an engine hoist to lift it and move it into position. How did you guys do it? That bed is heavy as heck with all the new wood. So lifting it by hand might be pretty hard for me and one other person.
![]() ![]() Join Date: May 2015
Re: How did you remount your bed?
me and a buddy pulled mine...but 4 people ,one on each corner, would be better
It's Better With Nitro
I have a bed lift that is basically a large "H" with adjustable arms that fit under the lip of the bed sides. It has a loop in the middle for either a shop crane or a trolly lift. I used my shop crane when I was mocking things up since I had more help then (holding it from swaying) and then used the cross bar on my lift with a couple of ratchet straps when I was setting it on the chassis for good since I was by myself.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Moderator
![]() Join Date: Dec 2012
I've done two. On mine, I left out a couple boards, and used my engine hoist and a strap to get it in place. On the second truck I did the bed vertical to save time on the board bolts, so I rounded up a few buddies to flip lower the bed to horizontal and up on the truck.
![]() Join Date: Jan 2011
Once with the lift arms and straps and once with four guys. Both methods worked fine.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Thanks for the replies. Looks like im doing the engine hoist route. Just wanted to see if there was another way besides brute force and the hoist.
I too have a four post lift, but used it to lower the truck off the bed instead of raising the bed off the truck. 4 straps to eye bolts from the bottom of the trusses used. After removing the truck, I then raised the lift up to sit the bed on it,which made it a cinch to disassemble.
Steve
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 Last edited by sstock; 04-07-2020 at 07:56 AM. |
I looked at one of the metal bed lifting tools made by Eastwood. I went to my lumber pile and took 1 4x4 and 2 2x4s and built one . Picked up a large eyebolt and drilled a hole in the 4x4. Used my homebilt gantry crane and lifted the bed off and then back on . Worked great. An A -frame or cherry picker will also do the job. Good luck
Good point, I could of used my gantry and trolley but that would of put the lift point in one place. Then you have to deal with keeping the bed level and not moving- swaying too while trying to install it with new paint an so on. Unless you could get some help. If you are helpless like me then it is different
1953 3100 261cu in, sm420, 3.55 torque tube, omaha orange 1964 GMC 1000 series,custom, 305E, sm420 |
The joys of having my 3 sons living with me, cheaper than paying rent!
P. ![]()
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
![]() Join Date: Sep 2006
I have used engine hoists and either straps or made a wood H frame as stated in another post. When I did this bed wood I never took the bed off the truck.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
I used a wood H frame and engine hoist. Had the bed off twice like this. It works great but extra hands will make it easier.
![]() Join Date: Dec 2009
